I have a NAKAMICHI MBR-7 IN WHICH THE (SIX) JUMBER SWITHES IN THE BACK WERE PUSHED IN THE WRONG ON/OFF POSITIONS. CAN YOU TELL ME FROM LEFT TO RIGHT WHICH SWITCHES GO UP OR DOWN?
From left to right: on,off,off,off,off,on
this is how mine was configured
Posted on May 17, 2008
    Sergeant:
    Champion:
  • 293 Answers
What type of processor you have?
Posted on Apr 08, 2008
SOURCE:
How to open Nakamichi CD Player MB-4s 7 disc musicbank. It has 7 our discs inside and we cannot reject them and we are unable to open the Nakamichi box.
Not really familiar with this one but most will have a very small hole somewhere on the front of the machine near the opening. A straightened paper clip pushed into the hold should open the tray.
Dec 06, 2016 | Nakamichi Car Audio & Video
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
[email protected]
Mar 14, 2011 | Car Audio & Video
On the back of the radio on a 1994 dodge what pin in the back is the hot wire goes on`looking at the back if it lift to right
The connectors are slightly different depending on which radio system you have. The wiring schematics only say connector 1 and connector 2, so I can't tell you which is left and which is right. All the systems use the same pins for the hot wires, however. They are pin #6 and pin #7 in connector #1 They are (as you may have guessed by the numbers) right next to each other. Pin #6 is RED/WHITE and is hot only with the ignition switch in the ACCESSORY or RUN positions. It is protected by fuse # 12 in the Fuse and Relay Box (Under the left side of the dash). It is a 10 Amp fuse. Pin #7 is PINK and is hot at all times. It is protected by fuse #F2 in the Power Distribution Center. (In the engine compartment, left side) It is a 5 Amp fuse.
Mar 12, 2011 | 1994 Dodge Dakota Club Cab
I need to know the order from front to back,left side and right cylinders on a 5.7 -350 chevy vortec engine.
the cylinders on the drivers side from front to back are 1 3 5 7 and the passenger side are 2 4 6 8 they will always be this way on chevys from the early years to now.if you have a six cylinder you just remove the last two 7 and 8.hope this helps you.remember odds on the left evens on the right.
Nov 14, 2010 | Chevrolet Silverado 1500 Cars & Trucks
I bought a paramax p-510 I want to setup connect it to my tv, what cable do I need
i have no idea to connect it either. Specially since the AV has only 2 jacks instead of three. I connected the two jack with DVD, and the front 2 speakers work and the sub too, however i have no idea how to make the surround and center speakers work. I have tried various variations, but i think the thing is a fake made for only 20 bucks speakers without much juice.
I might be wrong but this is the first av with only two jacks instead of three, even the cable they provide has three jacks
Sep 22, 2009 | Audio Players & Recorders
Nakamichi AV10. Re: left channel softer than the right one.
Hi,\
Its an issue with the tone switch activate and reactivate it to get back to normal volume on both speakers, and would suggest you to clean the switch with WD40 and it should resolve the issue
Jul 16, 2009 | Nakamichi AV-10 Receiver
Amp won't power up,anymore! Even with new parts installed,removed
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Jul 15, 2009 | Car Audio & Video
I have two powered speakers, and Ii just bought an amplifier. Can I still connect the powered speakers to the amplifier?
You are charging me to tell me how to fix it right?
And you want me to tell you how did I fix it for free? I Don't think so.
Bye...........
Feb 18, 2009 | Nakamichi AV-7 Receiver
Ford f150 1986
The firing order for the 4.9 L engine is 1-5-3-6-2-4, with the firing order rotation on the distributor cap going clockwise. For the 5.0 & 7.5 L engines, the order is 1-5-4-2-6-3-7-8, and the 5.8 L engine is 1-3-7-2-6-5-4-8. On all three of these engines, the distributor cap firing rotation is counterclockwise. Also, on the six cylinder 4.9 L engine, the cylinders are in a "straight six", with #1 cylinder starting in front, and going in order straight back to #6. The eight cylinder engines' cylinders all fire in order also, (standing in front of the vehicle looking back towards the firewall) with #1 being front on your left and going straight back to #4, and then #5 being at front right, going straight back to #8, with the distributor being front and center. Hope this helps you out.
Aug 13, 2008 | 1986 Ford F150 SuperCab
Open Questions:
Malwarebytes Antivirus Helpline 1*855*536*5666O% Number Madison, Mississippi Malwarebytes Antivirus Technical Support Phone Number $O=1+855+536+5666$ _tMICo resolve all Malwarebytes antivirus mail products. Malwarebytes antivirus mail is an American multinational company which was founded by Malwarebytes antivirus mailusing its company headquarters in Round Rock, United States of America.Contact Malwarebytes antivirus mailfor Setup & Installation Malwarebytes antivirus mailSetup Support & Installation Malwarebytes antivirus mailHelpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes antivirus mailConnect, Malwarebytes antivirus mailHelpline Phone Number you'll be searching out Malwarebytes antivirus mailConnect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes antivirus mailConnect. Get Malwarebytes antivirus mailSetup Instant Support Malwarebytes antivirus mailCustomer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes antivirus maillocate the approaches simplified to help you even if you aren't Customer-savvy. Let us undergo the method Of Malwarebytes antivirus mail Connect setup for Windows and for Mac Out. So, Outright here we go webtechie
Oct 21, 2019 | Carrier Computers & Internet
SBCglobal MAil CuStOMeR +-*/{1^/855~/536~/5666-} Service PHoNe TECHNICAL This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
Computers & Internet Logo
96 people viewed this question
Ekse
Marvin
Marvin
