Question about Bugaboo Cameleon Jogger
It is stuck in the canopy where the canopy hooks to the stroller. It has a round pop up nob
I'm trying to convert this brand new stroller to have the carry cot on it. one of the buttons to release the hood off the regular stroller is stuck. what do i do?
since it's new, you'll probably have to rock the canopy side back and forth while you are pushing the button. once you detach the the canopy a few times that will get easier it's just stiff.
at 3:10 she removes the handle bar. (don't mind the cheesy music). It also shows you how to get the bassinet on as well.
Nov 08, 2010 | Micralite Toro Red Stroller Frame
A round part where the front wire insert broke
No but you can buy a new fabric set for around $US150 in a whole range of colours.
Jun 01, 2010 | Bugaboo Frog Stroller
Canopy broken on my fisher price stand and ride duo stroller
I have the same problem FisherPrice customer Service is useless. I would even buy a new canopy frame
Jun 01, 2009 | Fisher Price Baby Gear
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Maclaren double stroller canopy
I need a double canopy for a black twin traveller maclaren
Dec 03, 2008 | Maclaren Rally Twin - Navy Umbrella...
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Sun shade / mosquito net doesnt stay attached!
Hello trollmor:
These are great questions. The mosquito net elastic loops are going to be fastened around the hooks under the canopy. In order for it to work properly, the elastic hooks that hold the canopy in place need to be removed and the elastic loops for the mosquito net and sun shade will take their place. The elastic should hold both shades in place properly.
If this does not work, please feel free to email me at strollerinfo@gmail.com.
Sincerely,
StrollerInfo
www.StrollerInfo.com
Jun 19, 2008 | Bugaboo Cameleon - Tailored Fabric...
Eddie Bauer Travel System - Removable Hood??
Took me awhile to figure this one out...
There are two bars attaching this hood to the stroller. The rop bar is obvious and removed by taking out 2 phillips head screwdrivers.
The bottom bar seems much more tricky as it seems "permanent".
Upon closer inspection, the lower metal "hood bar" goes into the side of a round clip. This round clip has a button snap in the middle of it. This round clip can be removed by pulling on it (not intuitive at all). It is not bolted on. It turns out it only encircles the metal bar it is attached to 3/4 of the way like a c-clip and will stretch to come off. You cannot remove the bar from inside the hood, but you can toss it all in the washer! Good luck!
May 24, 2008 | Eddie Bauer Lightweight Travel System...
Quinny Buzz Canopy
The canopy should just push onto the seat frame, they do need a bit of pushing though. its easier if you get the connector half on and then just push, will hear a popping sound. it took me a while to figure it out on mine and the instructions aren't the best.
Nov 25, 2007 | Quinny Buzz Jogger
Bugaboo Cameleon Jogger Logo
35 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
