Question about Lexmark Wheelwriter 6 Series II Typewriter
3 Lights flashing
I have a Wheelwriter 6 and 3 lights in the space area at the bottom right hand side of the typewriter and doing a quick flash all at the same time. The machine is also locked up.
Thanks
  • Lisa F Aug 05, 2008
    I have the same problem, I have changed the batteries and even switched the battery case from another WW6 and still flashing! I have taken everything out and cleaned out all the dust and still nothing.
  • Lexmark Master
  • 3,594 Answers
It probably needs a keyboard, but if you are knowlegable on these see my tip under WW1000
DickyO
Posted on Jul 17, 2008
    Problem Solver:
  • 5 Answers
The three lights flashing indicate the batteries need to be replaced.
Posted on Apr 17, 2008
When I turn on the typewriter there are six beeps and the line spacing lights in the lower right hand corner light up and flash, but the keyboard does not work. Is this something I can fix?
Your keyboard is bad. If you are mechanically inclined look at my tip under WW1000. You can contact Geo. Beyers Co. @
800-392-8085 for a rebuild, tell them O'Reilly sent you.
DickyO
Sep 20, 2010 | Lexmark Wheelwriter 1000 Typewriter
Line spacing lights 1 and 2 are flashing and typewriter will not work
Be sure the printwheel is properly installed also check for debris in the P/W area.
DickyO
Apr 02, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
After my Wheelwriter 1000 is unplugged or turned
It sounds like your keyboard is going bad. You can try my tip under WW1000 or you can contact Geo. Beyers Co. @ 800-392-8085 for a rebuild.
DickyO
Jan 06, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 6---when I turn it on, it appears to lock
There are a few possibilities. First lube the silver shaft that the carrier slides on (WD40 works well). Remove the printwheel and check for paper or ither debris in that area. After that you e
will probably need a tech.
DickyO
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Jul 01, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6
Usually means the keyboard is bad. Check the keyboard connecdtions. Sometimes a real pain to remove and reinsert them. What lights are blinking?
Jun 17, 2009 | IBM Wheelwriter 30 Typewriter
Space lights flashing
Tell me the pattern. Are they flashing or on solid? Do you hear beeps. Count the beeps. Is it a WW 30?
Jan 12, 2009 | IBM Wheelwriter 30 Typewriter
Flashing lights
You have a keyboard problem. The rt. connector has 7 contacts bussed together, wrap a piece of foil over that portion of the connector and plug it back in. BE SURE TO COVER ONLY THE 7 BUSSED CONNECTORS!
Nov 26, 2007 | Lexmark Wheelwriter 1000 Typewriter
Need a user manual
Oil rails not with WD. Machine oil.
I have instruction books $ 10.00 828-687-3929
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 6 Series II Typewriter Logo
262 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
