Question about Haier HWR08XC7 Air Conditioner
The temperature cooling won't go below 86 no matter what i do? is the AC shot?
  • Haier Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
I have the same A/C and am having the same issue. Always stops cooling at 86 degrees, which is the high end of the range to which the temperature can be set.
Have you had any luck in getting yours working?
Posted on Jun 29, 2010
Haier AC changing temperature by itself
Have you tried calling the manufacturer? If you need more questions for your Air Conditioning Repair needs, check us out online
Jul 05, 2017 | Haier Heating & Cooling
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
2003 BMW 325i a/c compressor won't turn on
either low gas or a the compressor soloniod /clutch packed up their the two most common causes
Dec 19, 2012 | 2003 BMW 325
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
Just need to know if the temperature should be higher to keep the room cool or lower...mine is in F and goes from 68 to 86 degrees F...Please advise if it should be lower at 68 degrees to keep the room at...
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
Jul 21, 2011 | Sunbeam Heating & Cooling
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
No cool air come's out. No temperature change at
have u tried recharging ur ac? u can buy the necessary recharge can with the gauge to recharge ur ac if that doesnt help it could b something more serious like a blower or ac pump?
May 25, 2010 | 2001 Mitsubishi Galant
GoldStar Window AC - Not Kicking Cooler On
check selector switch n cirkit board
Oct 27, 2007 | Heating & Cooling
Haier HWR08XC7 Air Conditioner Logo
616 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
