Question about Linksys Wireless-G Range Expander (WRE54G)
I have a range extender hard wired to the wireless router to set up. Best I can get is a blinking top light and blue bottom.
SOURCE: WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Posted on Jan 17, 2008
SOURCE: Loss of Connectivity
Unless it was installed by the big box retailer when they "optimized" the laptop. I did not install any additional Linksys software on the laptop. Let me double check to see how it is connecting, if I am not mistaken it is using Windows built in wireless management. (it also looks like there was some preloaded Sony software to allow it to be used in a wireless environment) I am wondering if both are trying to connect at the same time?
Posted on Mar 05, 2008
kleeper
  • 87 Answers
SOURCE: Internet Intermittent Drop Out
I know that it has worked previously, which frequently happens even though it may not technically correct. When software is changed on one or more computers, or seemingly, enough time passes, things go haywire.
Your cable modem connects you to the outside world, it assigns IP addresses by DHCP (if enabled), to each connected device, so does a wireless router. If you connect the WAN port on the wireless router to a regular port on the cable modem/router, your wireless router will recieve an IP from the first router. Then it will assign addresses similarly which could be the same range, This is known as double NATting. Since you connected the the wireless router as a hub, it only assigns wireless addresses, not wired ones. Since they may be in the same range, this could work, but not reliably.
Here is what to do;
  1. Do nothing to the primary cable router.
  2. Connect a laptop or other computer to one of the lan ports of the wireless router. Nothing should be connected to the other ports.
  3. Manually assign this PC the address 192.168.1.2
  4. Using your web browser on the PC, connect to http://192.168.1.1
  5. The default login is left blank, password is admin.
  6. Network Setup tab
    The Network Setup section changes the settings on the network connected to the Router’s Ethernet ports. Disable the DHCP server setting
    Wireless Setup is performed through the Wireless tab.
    At the bottom of the page click SAVE SETTINGS
  7. The Setup Tab - Advanced Routing
    This tab is used to set up the Router’s advanced functions. Operating Mode allows you to select the type(s) of advanced functions you use. Dynamic Routing will automatically adjust how packets travel on your network. Static Routing sets up a fixed route to another network destination.
    Operating Mode. Select the mode in which this Router will function. Since another Router exists on your network, select Router. When Router is chosen, Dynamic Routing will be enabled.
    Dynamic Routing. This feature enables the Router to automatically adjust to physical changes in the network’s layout and exchange routing tables with the other router(s). The Router determines the network packets’ route based on the fewest number of hops between the source and the destination. This feature is Disabled by default.
    From the drop-down menu, you can also select LAN & Wireless, which performs dynamic routing over your Ethernet and wireless networks. You can also select WAN, which performs dynamic routing with data coming from the Internet. Finally, selecting Both enables dynamic routing for both networks, as well as data from the Internet.
  8. Connect wireless WAN connector to one one cable router lan ports
The PC should be changed back to DHCP for its IP and everything should work normally. All PCs on the system should get their IP address from the primary router only and should be visible to each other.
Posted on Oct 22, 2008
mahryeahnne
  • 11 Answers
SOURCE: wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: Range Extender
Both router and range extender must be setup with the same SSID, encryption key and same FIXED channel assignment.
Posted on Jun 22, 2009
How do I set up a Belkin N300 model F9K1015 V1 range extender?
Its very easy just follow these steps-
1. Restart Your Modem First than Restart your Router And Extender
2. Please Your Extender With in 30-35 Yards Of Your Main Wireless Router .
3. Make Sure All Lights Are Blinking On Router And You Have Internet to your Router
4. Try Connecting The Extender Again See if That Works
For more details kindly visit
Belkin Range Extender Won Connect to Internet Belkin Range
Good luck.......
Mar 01, 2015 | Belkin Computers & Internet
Why Can't I connect my belkin wireless range extender with apple time capsule?
Its very simple just follow these steps -
  • Restart Your Modem First than Restart your Router And Extender
  • Please Your Extender With in 30-35 Yards Of Your Main Wireless Router .
  • Make Sure All Lights Are Blinking On Router And You Have Internet to your Router
  • Try Connecting The Extender Again See if That Works
For more Details kindly visit
Jul 05, 2012 | Belkin Computers & Internet
Trying to set up in wireless range extender mode a Belkin Wireless G Universal Range Extender. Once moved to another room away from routers and PC, the red 'searching' light continues to flash. Thoughts...
HI ....
I got Your issue....the searching light is blinking because its searching for a network ...tried scan and connect once connected will become stable...any issues let me know back
Thank u
Priya
Jul 10, 2010 | Belkin Wireless G Universal Range...
Can I add a 2nd wireless router at another location?
Your best bet is to use a wireless extender, this will extend the range.
Google search for these devices.
Feb 01, 2010 | D-Link AirPlus DI-614+ Wireless Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless Networking
try this this is a very very good info site
Apr 24, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Wireless G ranges expander
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
Jan 20, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G Range Expander (WRE54G) Logo
299 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
