Question about ASUS P5PE-VM Motherboard
Installed windows seven... keep having to reboot
After installing windows seven, we cannot restart or we have to reboot. and even then we have to fight to make it re boot
  • ASUS Master
  • 11,800 Answers
Bad install, do it again and this time don't load any other programs besides the security ones. Let it do all updates and test the behaviour again.
Posted on May 31, 2010
Windows 8 wont recognize datel game controller
Try this Access Startup Settings When the Choose an option screen appears, click or tap the Troubleshoot tile.
Next, click or tap the Advanced options tile.
Select the Startup Settings tile on the Advanced options screen.
Click the Restart button on the Startup Settings screen to reboot your computer again.
Disable Driver Signature Enforcement On the Startup Settings screen, tap the F7 or 7 key on your keyboard to select the "Disable driver signature enforcement" option.
Windows 8 will immediately boot to its typical lock screen. Sign into Windows 8 as you normally would - everything will look the same, except Windows will no longer demand driver signatures until you next reboot.
You can now install unsigned drivers as you would on previous versions of Windows. Windows will alert you if you try to install a driver that isn't properly signed, but you'll see an "install this driver software anyway" option you can choose.
Reboot When you're done installing the unsigned drivers, reboot your computer. Windows will keep using any unsigned drivers you've already loaded, even as it enforces signature requirements for new drivers.
Nov 15, 2013 | Datel Xbox 360 Turbo Fire 2 Wireless...
Making a bench machine on the tyan dual core pentium III mother board
Rebooting is tipical of Windows XP when there is an important error. Most of the time this error is coming from the hardware.
There is a way to know the error code that make Windows XP mad, but you have to eliminate the automatic restart option.
With your mouse right click on My Computer, select properties, select advanced and you should see something similar:
deselect Automatically restart.
At this point next time you will have the error instead of rebooting you will see a blue screen with some message at the top and some code at the bottom, please write them down and post them here.
In case you cannot even enter in Windows XP because is keeping rebooting too fast, try to do the above steps in Safe mode.
To enter in Windows in Safe mode you have to press F8 as soon as you boot and before you see the windows logo on you screen, then select safe mode and repeat the steps above.
Last but not least, please send me the exact type of motherboard, processor and memory that you are using.
Oct 30, 2007 | Tyan Trinity 450 (S2507S) Motherboard
How to run autocad 2004 in window 7 home premium 64 bit?
The problem is incompatibility with 64-bit AutoCAD 2004.
Find yourself a program called "VirtualBox" is free, and download it today as much as you find it ... once downloaded install it, and I installed it, run it.
The program comes in Spanish, is multilingual. so do not cause problems setting it up.
This program will tell you, what it does is set up a virtual machine on your computer. Which makes it possible to install by saying something, as an example, "Windows XP, or even Windows 98" on your current system which is the Seven.
Once set up VirtualBox, install XP, opr example, or even Linux, or you cualkier anotoje system and other system installed in your Seven, install Autocad 2004. and all you like ...
As a note, perhaps I can recommend, have a large hard drive to do this, or two disks installed, at least need a 10Gb recommended to do this.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | HP Computers & Internet
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
I keep getting shut down , and my computer has to restart over and over
Try using the recovery CD that comes with your computer if it has one.
If it keeps rebooting as windows boots or after it could possibly be an issue with your Windows install hard drive, memory or CPU.
Mar 16, 2011 | ASUS P4S800D-X Motherboard
I just assembly desktop with gigabyte motherboard and ADM CPU, RAM etc...after that i install os Window XP in the 500GB hard drive, the installation done successful, but the problem come out after i done...
This is not a hardware problem, it's a BIOS problem and install problem. Here is my suggestion:
1. Go into the BIOS and set your boot as a) CD-ROM/DVD-ROM
b) Hard Drive
[and it does not matter what is next just as long as the first two are as above.]
2. Reinstall windows os, when ask you want to format drive and install. (This will erase EVERYTHING and reformat the drive space.)
3. When the install is finish, REMOVE the Windows disc and reboot the system.
This should solve your problem. Sometimes if a file was not installed correctly and you leave the install disk in, windows will try to reinstall the files and go from bad to worst.
Good Luck
C2Solutions
Feb 08, 2011 | Computers & Internet
I have a laptop.when i turn it on it's windows keep loading and doesn't start..plz help
Insert the Windows Vista or Seven installation DVD, then reboot your laptop. Boot the DVD and then, on the Setup screen, choose "Repair my computer". This will automatically fix your problem.
Oct 01, 2010 | Computers & Internet
After rcovery keeps trying to reboot
Is it a recovery (from a recovery partition) you did or you installed from DVD or CD?
If from latter--cd or dvd...then reinstall or have the cd burned at a lower speed.
Dec 18, 2009 | Microsoft Windows XP Professional
Unable to reboot or log on since restore system to factory defaul
Go into the bios and revert to set up settings/default and reboot.RICHARDM69
Dec 08, 2008 | Acer Aspire L100 PC Desktop
Windows 98 install
It could be a memory related problem. Try to test your memory module by installing it to a different system that is surely working. If that system restarts, then you must replace the memory module.
Nov 20, 2007 | Microsoft Windows 98 for PC
ASUS P5PE-VM Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
