Question about Samsung WF328AA Front Load Washer
Drain cleaning When I went to clean the drain, I followed the instructions in manual. I opened filter cap and removed. When I did this, a small o-ring came out. Does anyone know where this o-ring is suppose to be positioned before I put the filter cap back in.
  • 159 Answers
If the O ring is about the size of the cap then it may be from there..If its tiny about diameter of a pencil then i would just put the cap back on,i don't think its anything to worry about to much.it may have been it the wash load itself & not from machine at all.
Posted on May 31, 2010
Siemens washing machine keeps washing
Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
Oct 03, 2011 | Siemens WM14S794GB Front Load Washer
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
In the fall of 2009 I bought a front load 3.5 super capacity washer. All off a sudden it wont drain or spin and makes a buzzing/humming sound. Cancel and the bowl spins freely manually
Hi
You have something caught in your drain pump. If you have the manual for your machine, it would have instructions.
You need to locat and open the filter for the pump. Please note the machine is full of water, and when you open the filter cap, all the water will flow out.
I am not familiar with Kenmore as we do not have this brand in Australia. However, with most machines the filter is located at the front right bottom of the machine. Some have a flap open door then a twist cap. Other machines have a kick plate with needs to be removed, then a twist cap.
Some machine shave a hose bleeder next to cap which allows you to drain water out manually before opening the cap.
Once you open the cap clean filter and also check inside the cavity with a torch to see if anything is blocking the pump propellors.
Sometimes you are not able to physically see the pump propellors, so the pump needs to be removed and checked.
Ash
Sep 11, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Unable to remove the plug to access to clean the drain pump. Details in user manual have been followed but plug does not appear to rotate enough to the point where it disengages for removal? Any...
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 03, 2011 | Washing Machines
Please my frigidaire fw506etf washing machine stopped draining water last night up until now. The start/pause light and program ready light blinks. I looked at the manual and saw I had not cleaned the pump...
You're right; the filter should have come out.Had the same problem with our Bosch, cap would not even turn! Suggestions, noting the paragraph in italics-
pour anticalc/limescale fluid into any gap there is around the filter. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
Good luck
John C
Mar 18, 2011 | Washing Machines
My 2005 F-250 is reading water in fuel. Where is the valve to remove the water?
You can locate the horizontal fuel-conditioning module (HFCM) mounted to the frame rail underneath the driver's seat. Place a drain pan under the HFCM. Turn the fuel drain lever outwards and let the HFCM drain into the pan until clean fuel is observed coming from the module, then close the drain lever.
I have heard of people having to do this 2 or 3 times over the course of a week to get the light to remain off.
It may be a good idea to replace the filter element while you are in there as follows:
  1. Remove the fuel-filter lid from the HFCM with an adjustable wrench turned in a counterclockwise direction. Place the lid aside. Pull the old fuel filter from the HFCM and clean the filter mating surfaces with a clean rag.
  2. Insert a new filter element into the HFMC until it is fully seated. Remove the old "O" ring gasket from the fuel-filter lid and discard it. Stretch a new "O" ring gasket (included with a new fuel filter) over the lid and work it into the groove. Lubricate the gasket with clean diesel fuel applied with your finger. Tighten the cap in a clockwise direction onto the HFCM with an adjustable wrench. Remove the drain pan from under the vehicle.
  3. Open the hood and remove the fuel-filter housing lid on top of the engine with an adjustable wrench turned in a counterclockwise direction. Lift the old fuel-filter element from the housing and clean the filter mating surfaces with a clean rag.
  4. Push a new filter element into the housing until it is fully seated. Replace the "O" ring gasket on the lid in the same fashion as the HFCM fuel-filter lid and lubricate with diesel fuel. Screw the lid back on and tighten with an adjustable wrench. Close the hood.
Where safety goggles and gloves and good luck.
Jan 01, 2011 | 2005 Ford F 250 Super Duty
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
Hoover washer model VHD9143ZD
Have the same problem. Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF position. Select again the programme and press the START/PAUSE button to switch the machine back on.
We recall having this problem with a previous Hoover washing machine and it was solved by cleaning the filter. The service manual recommends you clean the filter once a month. The procedure is as follows:
1) Open the flap
2) Only available on certain models: Pullout the corrugated hose, remove the stopper and drain the water into a container.
3) Before removing the filter, place absorbent towel below the filter cap to collect the small amount of water likely to be inside the pump.
4) Turn the filter anti-clockwise until it stops in the vertical position. Remove and clean.
5) After cleaning, replace the filter and lock by tightening the filter screw. Then follow all procedures described above in reverse order.
Hope that helps :)
Feb 15, 2008 | Washing Machines
Samsung WF328AA Front Load Washer Logo
87 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
