Question about Sprint M0-I-808190 Corded Phone (4723897500)
How do I program numbers in my spring landline phone which has the following buttons: redial, flash, memory and program. It is a radio shack cat. no. 43-5201. thanks.
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
Radio Shack telephone Cat# 43-3091 Need phone setup instructions incl. programming memory button
If you mean the Radio Shack 43-3901 then you may download a copy of the manual here.
Apr 06, 2012 | Lands Phones
How to install phone no. in ET 3576 to memory
I think most Radio Shack phones work pretty much the same. They don't have a manual available for yours so I'm not absolutely sure, but I've had a couple of their phones. To store a number in those, it was just three steps:
  1. Press MEM
  2. Enter the number to dial
  3. Press MEM again, followed by the location button (on phones with single buttons for emergency numbers) or the memory location (one or two digits depending on the number of memory locations)
Try these steps and see if it works for your model.
Aug 03, 2011 | Lands Phones
How would I program a number into this phone?
This is the way to program the numbers
  • 1.Lift the handset and press PROG button.
  • 2. Enter a phone number as you would dial it.
  • 3. Press PROG again and then press the corresponding memory button to store this number. Hang up immediately.
  • 4. The number is now stored into memory. The memory button in the lower right corner of the frame can be programmed for emergencies. Whenever the handset is lifted, a light will guide you to that button.
  • Note: Press the REDIAL button to insert a pause in the numbers you are.
Pleas this link, for the phone user manual http://www.startechtel.com/docs/76593.000_Manual.pdf
May 18, 2011 | Ultratec CrystalTone Corded Phone
PROGRAMMING SPEED DIALS ON TOSHIBA DKT2010H
To program speed dial press speed dial then redial then the bin number (10-49) and dial number then press redial. If you mean to program the buttons on the right hand of the phone this is done is syatm program 39 and the manual can be found here'
http://guides.idacomusa.com/
Jul 14, 2009 | Toshiba DKT2010H Phone
Redial, transfer buttons
Here is a link to program buttons.
If you want to program auto dials to see when people are on the phone, those must be programmed on a lighted button, follow the procedure to program the phone, and use the left intercom button and the 2 digit extension number.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Owners Manuals are missing after the office remodel
Redial is used by pressing the redial button to access the stored numbers, each press brings up another number. To dial the number you want hit the # key. i.e. to dial a number you called 3 phone call ago you press 'redial', then 'redial', then 'redial' followed by '#'.
Apr 14, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Old telephone resetting and entering new items in memory
Voca ADX 37: Set the switch on the side to "PROG" then enter a phone number and then hit the appropriate Memory Key or "Memory/Lower+Memory Key; when finished reset the switch to "NORMAL"
Nov 16, 2007 | Lands Phones
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Sprint M0-I-808190 Corded Phone (4723897500) Logo
Top Sprint Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sprint Lands Phone Expert? Answer questions, earn points and help others
