My monitor comes on for about three seconds when I turn the computer or the monitor off/on and then it fades to black. It looks like the computer is booting up fine when I can briefly see the screen but then the monitor goes black. Any ideas? (Right now, I'm on a laptop).
    Brigadier General:
  • 10,406 Answers
Connect the monitor to the "video-output" port on your laptop, to see if the monitor is working correctly.
You make have to tell the laptop to send the video-output to "both" the internal LCD screen and the external monitor.
If it works, then your monitor is OK.
Restart your computer, and keep tapping the F8 key, until you get a menu of startup items. Choose the 'VGA' startup option, to select the "minimal" device-drivers for your video-card. With the "minimal" drivers, your monitor should still be working.
Posted on May 31, 2010
What causes a Syncmaster 2253LW monitor to start ok and immediately fade.
The monitor may be failing. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 01, 2014 | Samsung SyncMaster 2253LW Monitor
Have a Acer x223w monitor and it fades to white and then fade to black. I looked at the caps and nothing look blown on both boards. When I turn on the monitor the acer pops up and no signal look fine. But...
Have you verified that the problem is indeed your monitor and not the video card on your PC? i would start by connecting the monitor to a laptop or another PC to verify that the same issue occurs no matter what the source. Once you've verified that, you're likely dealing with a monitor that requires repair or replacement. Hopefully it's under warranty. Hope this helps a bit.
Aug 13, 2011 | Acer 22" X223w LCD Monitor
The monitor fades to black, a few seconds after I turn the pc on (even before starting windows); the blue button keeps on. When I turn it off, and then turn it on again, it works for a few seconds, then it...
Simplest solution first; check your cables. If the connections are good, but it still doesn't work, try your monitor with another computer. If it works, you need to update the drivers on your computer. If it doesn't, the problem is with the monitor. If your computer needs drivers from LG for the monitor, you need access to another computer (or another monitor to go online). Go to LG's website and look for SUPPORT. Download drivers for your monitor specific to your operating system (Windows, Mac OSX, etc.) and install.
Mar 02, 2011 | LG W2252TQ Monitor
Screen is trying to black out on me, accompanied by a loud buzzing noise. This buzzing noise has been growing over the past few weeks, and now, today, my monitor has blacked out several times, at which...
well mine came with a three year warrintee, so iv sent mine back twice already, worst moniter, try finding your receipt and then going on to acer's online support
Dec 15, 2010 | Acer X233H 23" Monitor
The monitor goes black while on
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Hannspree HannsG HG281DP 28" LCD Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Screem Comes on brefly and then fades to black
go to control panel and click on screem after click on screem saver select none or try configurate to more time for to active the screem saver, and if it is not that you must take it to a technician
Jul 15, 2009 | Sony STYLEPRO SDM-S91 19" LCD Monitor
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
275 people viewed this question
David Payne
David Payne
