Question about HP LaserJet 9500n Printer
Printer did not show ready status, showing 13.20 error
    Scholar:
  • 75 Answers
13.20 is a generic jam message that appears when there is a piece of paper stuck in the printer or one of the flags in the paper path is stuck in the wrong position. Most times this error occurs when one of the flags in the facedown assembly is in the wrong position. One thing you can try is to turn off the power and open the right side door below the manual tray and sitck a piece of letter paper in that opening and then close the door. It will not quite fit right but try your best. Now turn on the printer and after initialization and warm up the printer will attempt to clear the paper path and will feed that sheet thru. If it goes thru the error may now be gone, but most times the paper will jam entering the facedown assembly and stop since there is a piece of paper stuck up there or the the flag is preventing the paper from moving. If it comes thru but you still have the message then one of the 2 flags in that assembly is stuck. Good Luck.
Posted on May 31, 2010
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  1. Locate and select the firmware for your printer.
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
Epson printer not working. computer showing printer with exclamation mark and status error
make sure you have installed the correct driver.uninstall then reinstall again.make sure printer is in ready mode
Nov 20, 2012 | Epson Office Equipment & Supplies
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
When a document is in the printer que under status it says Error
reboot your pc or laptop.unplug printer cables and plug again,check if there is paper jams located at the back
Jun 24, 2010 | Office Equipment & Supplies
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
Epson Stylus C60 InkJet Printer will not print
First  go to your pc and click on file, print when the window opens does it show your printer in there? is it set to THAT printer?  does it show as being Ready?
If not re download the driver,  then click on File, Print, right click on your printer and set as default.
Next double click on My Computer, ( or click on Start, Control panel, printers and faxes, put your mouse over your printer it should say Ready, if not then change the cable
Sep 20, 2007 | Epson Stylus C60 InkJet Printer
HP LaserJet 9500n Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
