Question about GE WPRE6150HWT
Will not change cycles automatically
The cycles will not switch automatically, we have to manually go in and switch the nob to rinse, drain, etc.
    President:
  • 1,430 Answers
The timer has failed. This is easy to replace there is a video at http://appliancehelponline.com/topwashertimervideo.html this should walk you thru the replacement. If you need diagrams or illustrations of your specific model enter your model # there.
Posted on May 31, 2010
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Model FDB750RCC1 goes through pre rinse cycles with no issues. Once the soap drops it puts water in an does not spray. Then drains. Fills again, just heats w no spray, drains. Etc someone said it may
There should be an automatic float valve that allows a certain amount of water to fill the machine automatically. There may also be a dial adjustment that allows you to say whether it is a full load or variations less than full. Check to see if both of your water feeds (hot and cold) are suppling enough water. If it is a top loader you can peek inside the machine at various times to see what is going on (there is a safety switch that will turn off the drum activities when you do and resume when you close it). If it continues to drain and fill on the wash cycle without actually having the agitator do any washing, you have a control switch problem! THat main control switch is not advancing as it should. Change it out!
Jan 02, 2013 | Dishwashers
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
Wife did a load of laundry. he washer filled and started to work but it would not drain spin or rinse. it will keep running the agitator if I turn the nob its self.
check for a bad door safety switch, you can locate the switch and the connection plug and unplug the switch, and add a jumper wire between the 2 connectors that lead away from the switch , spin, rinse, and drain, need this switch to work or the machine doesn't do those motions,
Jul 27, 2011 | Kenmore Washing Machines
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
WHen you start the washing machine. It starts to fill up than stops and all the buttons start to flash. then it stops after every cycle. then when it gets to the final cycle it freezes and I have to...
let check check first the DRAIN MOTOR PUMP it could be stuck with debri in the impellers , then check sensor switch located where you close the door , latch or magnetic switch ,it could be loose or damaged , then last the timer switch module , hope this helps AJ
May 23, 2008 | Frigidaire Washing Machines
Wont drain
Sounds like you have a bad lid switch.I would need additional info on the unit,make,model etc.
Nov 21, 2007 | Indesit W 123 Front Load Washer
GE WPRE6150HWT Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
