Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
When we try to turn on the tv, not with the remote, but from the actual tv itself the tv just clicks and clicks. So now we don't turn the tv off. We turn of the cable and the tv just stays on. Last time we turned it off it took 20 minutes of clicking before it came back on. Need help
  • Samsung Master
  • 8,457 Answers
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
Posted on May 31, 2010
Hi, I bought my LCD Philips 42PFL5603D/10 have a problem with it. Turn the TV on any program and after about 20 minutes the TV turns itself off and I can not turn on the remote, turn on the TV button on...
if you have electronic experience - open the back check the power supply for busted/leaking or swollen caps - replace them and i bet your tv comes back on - big problem with the philps/magnavox brands - well a lot of brands actually.
thanks,
michael
Apr 05, 2011 | Philips 42PFL5603D/10 TV
I have a 50" DLP Samsung that keeps turning off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Dec 09, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
I HAVE AN HCM 4215W SAMSUNG 42 INCH TV THAT WILL WORK FOR ABOUT 20 MINUTES THEN SHUT OFF...I USE THE REMOTE TO TURN IT ON BUT ONLY THE RED LIGHT COMES ON. IF I UNPLUG IT AFTER ABOUT ONE MINUTE THE LIGHT...
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours and that you TV is 4 years old more likely you are looking to replace you lamp;The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
If you can hear your TV fan working is NOT you power supply,but if you hear a constant clicking you BALLAST needs to be replace,
A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light.
You can find your parts at:http://www.discount-merchant.com/SearchResults.asp?Search=HD50LPW175?Click=52978
I hope this will help,please keep us posted.
Oct 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Tv keeps turning itself off and needs to be off for 5 minutes or more before allowing to be turned back on. Once on, there is a audible click and hum for about 2 minutes.
There is likely an overheated capacitor. Most likely in the power supply. It is actually extremely common now days, especially in newer electronics.
First try dusting out inside of tv and all the venting
Aug 27, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Power light keeps blinking green with no display
I would try leaving the TV unplugged for 30 minutes to let the TV reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
32PF9962 32''
Could be power supply failure
Mar 06, 2018 | Philips 32PF9964 32 in. Television
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
262 people viewed this question
Jerry Greenberg
Jerry Greenberg
