Question about Kenwood KW85 Air Conditioner
My air conditioner is not producing any water
My Kenwood 85 unit has been running since yesterday and hasn't produced a drop of water???
it is blowing cold air but doesn't seem to be working as it should be.
    President:
  • 3,085 Answers
It will take a full season of runnig to produce a cup of water. Most moiisture evaporates and is exhausted out the hose.
Posted on May 31, 2010
How can I stop my air condition from blowing out water whenever I turn it on?
Check the outlet where water naturally drains out of the unit, because AC, if working properly, produces water as waste that it takes from the air. Sometimes these things get blocked and also remove and clean the filter if there is one.
Aug 22, 2014 | Heating & Cooling
Kenwood 85 air conditioner is not cooling as well as before last time I put it on. Why is this?
Clean air intake filter and take outer cover off clean cooling coil tubed with soap and water blow off with low pressure compressed air under psi.should run good.
May 17, 2014 | Heating & Cooling
Does this air conditioner need water
Air conditioners don't need water. if it is runnibng properly and blowing cold air it will produce water on the condensing coil. Look at the coil. If you see a lot of ice, turn the unit off and wait until the ice melts. If the ice returns it is probably low on freon. This must be taken care of by a licensed air conditioning tecnician.
Nov 17, 2012 | LG BG8000ER Air Conditioner
Hi, I have a GE Portable 120 Volt Room Air Conditioner Model: APH10AA. It is producing a humongous quantity of water every times it runs. For 8 hours of use at night, it produces close to 3 gallons of...
with real high humididty this will be a problem I might suggest that you find some kind of pair and place it inside the pail but stacked onotp a a block to keep the unit dry until things dry out a bit .. Its the weather not the unit thats the problem let me know
Jul 23, 2011 | GE APH10AA Air Conditioner
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
I have a Matrix dehumidifier which says it`s a Refridgerant,does it means it`s like an airconditioner?If so how do you use it nothing on the manual to illustrate & do you fill it with water...
Dehumidifiers are small Air Conditioners that blow their cool air over the condensing coil rather than into the room. They work exactly like an AC unit except they don't blow their warm air outside. If you can install an AC unit of about the same size, you can dehumidify AND cool for the same energy costs. All you should need to do is plug it in and run a hose to a drain or keep its condensate tank emptied. By the way, the water it produces is free of minerals and some people say its good to wash your hair with. (?)
Apr 01, 2011 | Heating & Cooling
What would cause a rooftop a/c unit to leak water inside the trailer only when the unit is running?
There is a drain to run the water outside and it is plugged...this units produces water when running as it dehumidifies the air...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Kenwood KW85 Air Conditioner Logo
370 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
