Question about Epson C31C412144 Thermal Printer
Printer head Normal paper was used in the printe. It printed blank receipts. Can the paer damage the printer head. Avril Green
    Brigadier General:
  • 10,406 Answers
Thermal paper uses heat to "write" onto the paper.
Normal paper is heat-resistant, and so it would be "blank".
Probably, you're OK. Try using thermal paper -- you've got nothing to lose, at this point.
Posted on May 31, 2010
I have a Agptek receipt printer, i replaced a paper roll but the prints are blank
As a rule some printers use thermal paper and if the paper is installed inside out (Backwards) the wrong side is against the print head. If it is an INK system, the ink is dry.
Feb 05, 2018 | The Office Equipment & Supplies
My printer is working as normal but the paper comes out blank? yes i have ink
Print head/s blocked ,try running a head cleaner programme or change cartridges....... If you are not using original cartridges, try replacing.
Aug 13, 2016 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
Feb 26, 2010 | Office Equipment & Supplies
Printer set up but will not print. newly installed printer will not print even a set up page. Will not print the sample page using zebra label designer.
Are you using thermal paer or thermal transfer?
Get one label and place a cigarrette lighter next to it for less than one second. If the label turns dark like supermarket receipts, then is thermal paper. (In this case let me know and we will try to diagnose what the problem is)
If the label does not turn dark at all, then you have the wrong type of labels for this printer unless you have the option to use ribbon.
Feb 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Epson C31C412144 Thermal Printer Logo
286 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
