Question about Gateway 7330GZ Notebook
I have to keys that will not type at all sometime the g works after hitting a couple times the t and Y don't work at all laptop keyboard my 7325GZ
    Master:
    Sergeant:
  • 482 Answers
If you every got water or anything on them they will not work, and a new key board is what you need.
Posted on Apr 10, 2008
    Scholar:
  • 67 Answers
You can clean a sticky keyboard usually. First of all, put it on it's side and blow out the dirt with compressed air". Then turn it upside down and shake it a bit. More stuff came out? Blow it off again.
Then dip Qtips into some rubbing and clean around the keys. If a key is easy to remove, do that first. Try the three keys you mentioned. Good luck with it!
Posted on Apr 08, 2008
  • AL Arena Apr 08, 2008
    That's rubbing alcohol, sorry!
  • 871 Answers
Hey there angles821
you may think that you have a faulty keyboard but thats not true...
you maight want to have the keyboard cleaned from the inside and have the rubber checked if its still ok. sometimes this things happen to laptops...
Do i have a faulty "A" key or a faulty keyboard?
You will need to purchase a keyboard replacement. Thanks for using FixYa! You can purchase them rather cheap at Amazon.com
Feb 06, 2012 | Dell Inspiron Computers & Internet
My keyboard only works when it wants to, i thought it was a virus but my laptop is now virus free and my keyboard still does not work properly, sometimes does not work at all sometime the number two holds...
If you have a sticky key that you know of you may have a couple that you haven't noticed. The number 2 key sticking usually means something was spilled on it at one time.If nothing is spilled you will only see the keys at the sides act up and usually the longer or larger ones. These act up from not hitting them straight but at an angle.
The next time it does this try thumping the keyboard to jar stuck keys loose. The key may look ok but is stuck just enough to do this. You just need to flick a finger at the keyboard to knock them loose. You may have to do this a few times before it dislodges the offender. On a normal keyboard you flip it over and knock on the back like knocking on a door to do this. On a laptop you can't hit it as hard.
If the keyboard keeps doing this your option is to replace it. Depending on the make and model a new laptop keyboard is about $45-$75 and is installed in a few minutes.
Sep 02, 2011 | MSI Computers & Internet
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
My Asus PC1005HA netbok has developed a keyboard problem. Sometime some keys will now work, sometimes when I hit a certain key a series of 9's will continue to type until I hit the escape key. The problem...
Daniel, Sounds like you may have a virus. Hardware issues are usually an all or nothing, either works or doesn't and wouldn't change to different keys on reboot. I would suggest running a virus scan with updated virus definitions. Neil
Dec 15, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
Sometimes the keys work and sometimes I have to
take a vacuum cleaner and clean the keys nicely... might be something is stopping it ,,, it still the problem is there u would have to replace it
Jan 12, 2010 | Dell 0Y3740 Keyboard
I have an Acer Aspire 5515 laptop. When Im typing the lers sometimes dont show up. Ihav to hit the letter key a couple times for it to work sometimes. any suggestions on how i can fix it?
first of all u need to remove ur power plug and the battery
then pull a little Aciton around each button which stuck
use any cool air dryer and direct it through these buttons which u have put an Aciton on it
keep ur cool dryer ( not hot air cool air plz) about 5 min. directed to the buttons
leave it about 30 min
if this not work then try this
u need to clean ur keyboard cause it seems that ur key is stuck so u need to dissassemble ur keyboard and clean the carbon points in ur keyboard (after u dissassemble it) using Aciton and tishue
otherwise u need to change ur keyboard
Jul 30, 2009 | Acer Computers & Internet
Keyboard is not responding to every letter I type
see if your keyboard have powder, do you need to clean it, if is not resolved this, see the keyboard in the control panel.
Jan 03, 2009 | Microsoft Multimedia Keyboard/Wireless...
Gateway 7330GZ Notebook Logo
199 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
