Question about Philip Stein Teslar Stainless Steel Small Watch 1-G-CI-SS
Top half of watch stopped. Bottom half still working
Top of watch stopped working. Bottom half still working.
Product has been to the factory 1 1/2 years ago for servicing.
  • 299 Answers
The first thing to check is the battery. After 18 months it could be weak or each of the movements may use a separate battery. Take it to a watch shop or jeweler and have it tested.
Posted on May 31, 2010
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Set time on TIMEX 1441 sports watch
To set your watch:
1. Press the top left button while the screen shows the time. The seconds should begin to flash on the screen. 2. Press the bottom left button to switch between seconds, minutes, etc. 3. To increase a number press the bottom right button 4. Press the top left button to stop changing/confirm the time you have set.
This is the general way to set most watches
Mar 30, 2011 | Timex Watches
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
Mar 16, 2009 | Swatch Irony watch
Trying to set time on nike watch
1. Press the bottom left button(MODE) to put on Time mode.
2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
5. Press the LIGHT button to finish.
Mar 13, 2009 | Nike Watches
I cant reset the time on my watch it is a stark -1082
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Oct 28, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
The stop watch second and minute do not reset to 12 . Dallas
To reset the stop watch unscrew the stem and pull it out 1 click. Then press the buttom to the top of the stem and it will move the minute stop watch 1 minute continue to press to get it set to 12. Do the same with the bottom button to get the second hand stop watch to 12.
Sep 01, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Timex 1440 sports watch, WR50M
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Feb 15, 2008 | Timex 1440 Nylon watch
Philip Stein Teslar Stainless Steel Small Watch 1-G-CI-SS Logo
223 people viewed this question
Top Philip Stein Teslar Watches Experts
Jimmy Accardi
Are you a Philip Stein Teslar Watch Expert? Answer questions, earn points and help others
