Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
No display even after the system boots
When i start the Comp, Processor fan is running but the monitor is totally blank (Only the power button blinks). There is no beep sound when i start my computer (Ever after removing RAM).
System has an onboard display car.
Please help
    Brigadier General:
  • 10,406 Answers
You either have a dead CPU or a dead motherboard or a partially-dead power-supply -- the power-supply should supply different voltages to different computers, i.e., one voltage to spin fans, and a different voltage to power the RAM, and a different voltage to power the motherboard. So, it can be "partially" dead.
Borrow a power-supply, and try that first.
If all else fails, take the computer to a qualified technician.
Posted on May 31, 2010
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
When i switch on the monitor the on/off button blinks and i don't get a picture. johanalvemalm@people.net.au
Most monitors will behave that way if they don't get a signal from the computer so there's nothing to display. A quick check of the monitor itself is to disconnect the signal cable from the computer and then turn the monitor on. Most monitors will display some kind of a message that there's no input and to check your cable connection. Then the power indicator changes color as the monitor blanks out.
You will probably find that your computer isn't starting up when you turn on the power. A common computer problem is that it will turn on when you press the power button, showing a power light and you'll hear the fans inside start running, but it never actually starts running. Then there's no video to the monitor and you see the trouble you described.
The monitor may still be bad. If everything seems to be starting normally and you hear the Windows startup sound through your speakers, but the display stays blank, try another monitor. If that one works, you'll need to have the bad one serviced or replace it. If the test monitor is also blank, the video circuitry in your computer has failed. If the video is built into the motherboard, you can install a plug-in video card as a replacement.
If the computer is turning on but never starts running, that can be a pain to figure out because several things can cause the trouble. The most frequent causes are a bad power supply or motherboard. Bad RAM or a defective drive or other device connected to the motherboard can also keep the board from starting up. The processor itself can fail, but that's not common. I start by removing everything except for the power supply, processor and fan to see if the motherboard is starting. If the motherboard doesn't give a "no memory" error (usually a long beep), you need a power supply or motherboard. Otherwise, the basic hardware is fine, and you can start replacing parts until the trouble comes back, and then you'll know what caused it.
Good luck, and thanks for using Fixya!
Dec 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
Systemax Ascent HA3200 RTS won't boot - fans come on - no display
The motherboard seems OK as it is displaying signs of life. The Monitor should display something before booting up, which it is not.Please do the following. 1. Remove the RAM and reinsert the DIMMs into their sockets and boot up. 2. Disconnect the HDD data cable from the HDD and the motherboard and reconnect. Boot up. 3. Disconnect the monitor and reconnect. Boot up. At boot up press F2 and set the PC to default settings. Boot up. Later when you want to apply your settings, keep noting down what you did when. Just in case.
Jul 17, 2010 | Systemax Computers & Internet
I have a blank screen on startup. The fan and
ur RAM is corrupt or
ur VGA driver is corrupt...
try this
pull out all power and power cables
and keep pressing the power on button on PC for some time with NO POWER and put back the power and switch on
Jan 10, 2010 | Gateway 5310 (1008368) PC Desktop
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Display is blank
This may not be the monitor's fault, it should flash a front panel LED when power is applied and most monitors will now flash a message if they are healthy but have no input signal.  Watch if your keyboard lights flash at power on and then the hard drive light on the system box to see if the computer is even booting.
If the system seems dead, you may have to open the case (only a few screws hold one side) and, with the power off, ground yourself on any bare metal you see and then pop the memory boards loose and then reseat them, trace each plug from the power supply (normally a silver box into which the AC is plugged in the back) to its end and if connected, disconnect and then reseat the plug.
If you have an accumulation of dust bunnies, blow them out and if any fans are carrying a bunch of dust, use a clean paint brush to free the blades a bit. I don't recommend using a vacuum since they can produce a ton of static charge and that can be death to low-level ICs.
I generally will reconnect everything external to the system box and turn on the power before reattaching the side panel removed for access; that gives you a chance to check if the CPU fan is running and any others that might not be visible once the case is buttoned up.
Good luck-
Oct 24, 2008 | Computers & Internet
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
131 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
