Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 903lt Lawnflite and the engine stalls every time I try to engage the cutters by lowering the engaging lever. What am I doing wrong or how do I correct the problem. The Lawnmower starts and drives perfectly well. Thanks Ian
Use higher revs,
ensure you are not in reverse
get mower moving first then once driving forward then engage blades
Posted on Jun 07, 2010
  • dbo4ner May 27, 2011
    Complied with above direction but engine stalled. Where is the Deck lowing arm safety switch locacted ?
  • stevemet Jun 27, 2011
    Silly question...but do you have the grass collector on the back? The blades won't engage unless it is fitted.
When I push up lever to engage the lawn mower blades it will not engage them and will stall the engine
If the operator seat saftey switch is defective the engine will stall.
safety-seat-micro-switch-fits-husqvarna-lr100-lt100-lt130-ayp-craftsman-rally-jonsered-mowers-532121305-121305-450-p-soavr15tiwcrglcekobpw2on-2-5.jpg Hope this helps?
Jun 23, 2017 | Garden
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Lawnflite 703 cuts out when I try to engage blades with pto lever
are the blades stuck on something or seized up , ck to see if they are not bent and stuck on something like the deck
Mar 07, 2015 | Garden
MTD JE135A wiring diagram The engine cuts out when activating the lower lever. In line micro switches test OK
I think the carb may be plugged up restricting flow to the engine,to lean and the engine will stall while engaging the PTO...
Get carb cleaned,and adjusted as needed .
Sep 30, 2014 | Mtd Garden
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Hi, I have a westwood t1500 with B & S engine which starts fine also runs fine with cutter disengaged,when cutter engaged it sends out clouds of white smoke and idles to a halt. Any ideas Regards ...
Sounds like the cutter is not turning free causing the engine to drag down and stop, I do not think the B&S engine is the problem. I have rebuilt dozens of these engines and most of the problems with a Briggs engine was dirt in the gas or carburetor that needed needle valve cleaned . If the cutters turn free, check for a bad or out of adjustment safety kill switch that engages and stops the engine as the cutters are engaged.
Sep 06, 2011 | Garden
Mower wont engage
The problem is in the park brake circuit,either the wires are off,the switch is bad or the park brake is on.Also check the switch under the hood near the linkage for the pto lever.
Jun 05, 2010 | Garden
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
Stalls when engaging cutter blades
The shaft that holds the blade could be rapped with something or needs a new bearing. Check again next to the deck, try a little WD 40 on the bearing.
Jul 09, 2009 | Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
436 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
