Question about Refrigerators
Whirlpool Frostfree Fridge/Freezer
I have an upright frost free fridge/freezer. The fan keeps stopping & starting sometimes only for a few seconds at a time going on off on off. I have cleaned it and got rid of the ice that was there and left it switched off for a few hours, but when I switched it back on it was still happening. I then cleaned the back of the freezer and noticed that there is some water in a plastic bit, on top of the motor, and that there is some white stuff a bit like melted polystyrene coming out of the bottom of the freezer just above where this plastic bit with water is. The motor also feels quite hot. What should I do to try and stop the fan going on and off.
Cx
    Novelist:
  • 184 Answers
IF THE PLASTIC CUP WHERE YOU FOUND THE WATER IS IN THE BACK WALL OF THE FRESH FOOD COMPARTMENT, THAT IS WHERE THE DEFROST WATER EXITS THE REFRIGERATOR AND GOES DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE WATER IS TRAPPED UP IN THE CUP, THERE IS A RESTRICTION IN THE DRAIN. IF THERE IS A BACKUP OF WATER IN THE FREEZER COMPARTMENT, IT COULD HAVE REACHED THE DOOR SWITCH. ON COME MODELS, THE DOOR SWITCH NOT ONLY TURNS ON THE LIGHT, BUT ALSO TURNS OFF THE FAN WHEN THE DOOR IS OPENED. IF THE SWITCH IS CONTAMINATED WITH WATER, IT MAY HAVE TO BE REPLACED.
IF THE MOTOR IS HOT TO TOUCH, IT MAY ALSO NEED TO BE REPLACED. THE BEARINGS MAY HAVE WORN OUT AND CAUSED THE FAN TO QUIT.
Posted on Apr 08, 2008
Freezer fan only run sometimes
If you nudged the fan and it started working it could be defective and needs to be replaced or it could be freezing up because of freezing condensation. Be sure that all the coils under and behind the fridge, if there are any,
are free from dirt and dust. If this is a refridg/freezer be sure the air vent between them, on the inside, is not blocked by anything. The airflow is necessary for proper temp control.
Apr 20, 2014 | Whirlpool Washing Machines
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
