Question about Whirlpool Duet GHW9150P Front Load Washer
On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
Says componet locked and I am not ble to unlock it. Can someone please tell me the method used to unlock the machine so i can wash clothes? Thanx
  • 5,081 Answers
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Posted on May 31, 2010
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9300PW4 .... The control lock is on .. I did get door to open, It will not shut off and none of the cycles will light up or start.. Please help..
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Control locked
On some front loading washer there is a button that when held for 3 to 5 seconds will lock the control panel so young children can't change settings. Look at your control panel for writing under a button that will tell you to hold down to lock or unlock panel.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer is LOCKED ! I need it UNLOCKED !!
Push and hold the button that looks like a pad lock for three seconds and a beeping sound and then it should unlock. Depending on your model. Let me know.
Apr 06, 2009 | Whirlpool Washing Machines
Unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Controls Locked - How to Unlock?
These are seperate problems, F 02 on whirlpool is a drain issue, this is were you need to remove the three hex screws on the kick panel below the door and using a bucket remove the cleanout on the pump and drain what water comes out and remove the filter and check the pump for damage. The other problem is a duel feature button that needs to be held for 3 seconds to unlock, I am fuzzy on the location, look carefully for the writing blends in with the panel.
Sep 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
find button with lock emblem underneath or a control lock button hold down 3-5 secs
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
266 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
