Question about Dishwashers
ASKO 1474 - runs through full cycle, but at the end, all lights on panel flash constantly & the drain pump is still running (water is all gone). Won't stop when power button is pressed, but will stop eventually with all lights still flashing. Is there any sequence of pushing buttons to get a diagnostic fault code with blinking lights? Thanks!
  • Dishwashers Master
  • 2,605 Answers
Hi, Welcome to Fixya. To answer the question re: error codes, the flashing lights is the error code with Asko dishwashers...at least your generation based on the info of it being a 1474. It is indicating a drain fault and therefore the overflow switch in the basin has been activated. It can also be activated by a plugged pressure switch or pressure switch hose. First step is to check for plugged fine filters in the sump area. Remove both filters and clean them thoroughly in "white vinegar". Next check for water in the basin by removing the kick plate, but first **turn off the power at the breaker panel**. If the basin is full of water, absorb the water or remove it with a "shop-vac". Run a cycle you normally would and watch for leaks or perhaps the unit is overfilling slightly throughout the cycle or timing out on the drain so it ends up exceeding the fill level by way of a drain pump fault. There are several possibilities as you can see, the more you can rule out on your own the better. I would also suggest checking the drain hose for debris or obstructions under the sink or where it connects to the home plumbing. Ultimately you may want to call in a pro. If so be sure they are familiar and proficient with Asko products, otherwise it could cost you more in the end. Let me know how you make out and I'll give you some other things to check if need be. Hope this helps move you forward, good luck. Macmarkus :)
Posted on May 31, 2010
  • 6 more comments
  • panne1950 Jun 03, 2010
    Hi - thanks for the quick response. I've been working on the DW for the last few days & here is my results:
    I used a shop vac to blow back into the drain line at the sink end. I also took off the wash tower arm & blew back into that line. There were a few unpleasant pieces of gunk released. Then I went through all the wash cycles 2x with the wash arm off and with SUCCESS!!! The cycle ends with all red lights not blinking....!!!!
    So, I have successfully fixed the drain fault but might have found another problem. There was one cycle where lights #2 & #3 were blinking at the end. What does that mean?
    Thanks!
    Macmarcus - another quick question - the plastic screws that hold down the filters have broken (which likely let gunk into the drain line since I remove those a lot to clean the filters & the filters are never secure)
    Do you know of ant tricks to keep the filters in place without those screws or a hardware store common item I might buy to replace them>
    Thanks, Paula
  • Mark MacDonald
    Mark MacDonald Jun 03, 2010
    Hello again,
    sorry I haven't been able to reply sooner but I'm out doing on-site calls today. As far as the lights flashing I'll need to refer to my diagnostic literature when I get home, ( since the 1474 is an older model I don't recall the code you're mentioning off the top of my mind ) but the screws are available at "repairclinic.com" for about $7. The part number they use is # 722055. I'll post back in a few hours or asap.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jun 04, 2010
    to follow up on your earlier inquiry regarding the 2nd & 3rd flashing lights. This is an error code for a faulty heater or thermistor. As for confirming or dismissing either component being at fault it`s a matter of checking for burnt wires at the element and for a poor thermistor connection at the control board.
    Following this you`ll need to check the ohm value (resistance) of both components. Obviously ( or not ) this will require a "multimeter" or "ohm-meter". If you are not familiar with performing these test`s or are not comfortable doing so I`d suggest calling in a pro, just be sure in doing so they are familiar with Asko products or it could quickly cost you more then necessary.
    The element should simply be an 0 ohm value and the thermistor between 40k and 60k ohms ( 40,000 & 60,000 ) at approx room temp.
    Ultimately this can be a control fault as I`ve experienced first hand, typically right where the thermistor connect`s to the control the solder becomes cracked therefore provoking the error code.
    Let me know what you find or if you require further assistance.
    **Please turn off any power to the unit before attempting any service**
    Good luck.
    macmarkus :)
  • panne1950 Jun 04, 2010
    macmarkus :)
    Great info... The lights only came on once, so it's not a recurring problem. I will check out the resistance. Are there any schematics available for this machine so I know the basics? There is no ASKO repair person in the area - I've had to repair my ASKO washer & dryer myself, but I need a starting point.
    Paula
  • Mark MacDonald
    Mark MacDonald Jun 05, 2010
    Hey Paula,
    I guess it`s good the error only occurred once, perhaps it was related to low water temperature ?
    I don`t know how you`d go about gaining a wiring diagram aside from the diagram which is usually located in the machine and either in the control panel or the kick plate at the bottom. Have you checked either location ?
    If after checking the resistance values and searching for the diagram you don`t find one, I could scan mine ( a generic diagram for your generation Asko dishwasher ) on my pc and try posting it or emailing to you if you provide an address.
    Let me know how it goes and good luck.
    macmarkus :)
  • panne1950 Jun 06, 2010
    Macmarcus - thanks for the info, I haven't taken it apart yet, so I didn't know about the schematic inside. I think I'm ok with this, and will try to check it apart in the next few weeks. You have certainly been a great help!
    Paula
  • Mark MacDonald
    Mark MacDonald Jun 06, 2010
    Hello Paula,
    glad I could assist in any way, let me know how it goes or if you need any further help. Please do take a moment to rate the assistance positively which you have received.
    Thanks again and good luck.
    Macmarkus :)
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Mar 26, 2010 | Asko 24 in. D3250 Built-in Dishwasher
All the lights stay on after a cycle completion even after I siphoned all the remaining water in the filter sump.(After opening and closing the door. ASKO model 1585)
Hello, the reason for the light flash error is the unit either didn't drain properly, overfilled somehow or has a leak which is filling the "overfill basin" ( it's designed to, that way it doesn't get to your floor...in theory ). Check your drain hose by removing it where it connect's to your home plumbing via under sink pipe or food diposer/garberator. You'll also need to remove the lower access panel, or kick plate as it is sometimes referred to, and absorb the water in the basin before it will run a cycle...or wait a few days for enough water to evaporate from the basin ( shut off the power/breaker before doing so ) then look for evidence of a leak. Check at the fill valve, (to the left) the drain pump, (slightly to the left-center) as well as the circulation pump & hoses, ( it is much more difficult to see...directly behind the big gray main sump assembly). That should get you moving forward. The Asko can be a challenge to work on if you've never worked on one. That is why I usually suggest calling a pro, preferably an authorized Asko servicer. It may save many unessasary part's being changed as I see too often with these. Hope that help's, good luck. macmarkus :)
Feb 28, 2010 | Asko 24 in. 1585 Built-in Dishwasher
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Jul 07, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
D3250 drain blocked error
usually these are blocked at the discharge end under the sink, especially if the hose is hooked to a copper pipe then shoved down the plumbing standpipe. It could also be in the hose behind the dishwasher if someone has fitted an extension onto the hose and used a small diameter coupler. Run the dishwasher on any cycle...if there is standing water you should hear the drain pump run first...if there is no standing water run it on a rinse and hold cycle. at the end of the cycle the pump will run. if you hear the pump, but no water is ejected out the drain hose under the sink, then you most likely have a clog in the hose near the end or in the middle if it has an extensio. if you dont hear the pump run, then its a bad pump and you need a new one (parts like that are covered for 5 years if you use an ASKO servicer) Good luck!
Nov 03, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
161 people viewed this question
Top Dishwashers Experts
