Question about Keurig B60 Coffee Maker
Keurig B60 says "Not Ready" and then shuts off before pulling in any water. It's only a few months old...
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig B60 will not brew. The "ready to brew"
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 04, 2011
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 12 Answers
SOURCE: keurig b60 coffe maker will not do anything.
These brewers are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of the B77's & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
Posted on Feb 15, 2010
Haven't used our b60 for a few months. It comes on for awhile then shuts off, it never says "ready"
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 17, 2011 | Keurig B60 Coffee Maker
My B60 keeps on flashing not ready and non of the buttons works the only way to stop flashing is to pull the cord out!!! What should i do?
heatman101
Sep 08, 2011 | Keurig Special Edition B60 Coffee Maker
Having same problem with B60 turns off after 1 minute and little circle won't go away.After unit was stored for 5 months, So this is what I did. 1. I took it over to the sink and turned it upside down and shook it. 2. I dried out the whole where the water sucks up and blew through there with a straw. 3. then I sucked water out the rubber tube up top for the over flow. Then I put vinegar in the intake whole and put vinegar in the tank and let it sit overnight. When I got up in the morning i turned it on and after 1 min it shut off again so I restarted it and after a couple minuets it started to heat and my display came back and circle disappeared. Problem solved. Not sure which one worked but it is now working fine and I am now descaling it.
Feb 25, 2011 | Keurig B60 Coffee Maker
I bought a new Keurig and I don't know how to drain the water out of my old keurig model b60 coffee machine. Please instruct
Get one of those computer acnned air things and blow the air thru the hoses that go into the top of the res.
Be ready as you will have water flying everywhere.... best to have it in the bathtub when you do that...
Only way to get all of the water out...
heatman101
Jan 30, 2011 | Keurig B60 Coffee Maker
Keurig b60 coffe maker will not do anything. always says not ready and shuts off. will not pump the water out of resavoir. I have taken apart and cleaned the strainer in the water line and it worked one...
Feb 14, 2010 | Keurig B60 Coffee Maker
Jan 01, 2010 | Keurig Special Edition B60 Coffee Maker
I just bought it Keurig b60 it displays blinking not ready and no buttons work what i need to do to make it work
I have the same one. fill side tank with water and close down place to put coffee. it should **** up some water. Than in a few it will say ready to use. Hope this helps....
Jan 26, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
267 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
