Question about Encore PC Tools Desktop Maestro 2008 for PC (705381141501)
My son installed desktop maestro and his computer crashed
His computer doesn't start - gives message
problemsignature startup-repair-offline,
problemsignature #01 & 02 6.1.76600.16385
problemsignature #03 unknown
problemsignature #4 21215624
problemsignature #5 autofailure
problem signature #6 21
    Guru:
  • 1,705 Answers
Try booting the PC, pressing th F8 key repeatedly as it trys to start.
You should see a page offering several modes of starting.
You can 1) Start in safe mode and assuming it work ok, use the control panel to uninstall the soft ware. Then reboot normally
or 2) Start in safe mode with networking, assuming this works, go to filehippo.com download and install a programme called Ccleaner. Using the "Startup" option, delete all programmes out of the start up menu execpt for antivirus and firewall programmes. Then reboot normally. If this doesn't work go to option 1.
Good Luck.
Posted on May 31, 2010
Windows xp sp3 will not start just frezzes . canot get into safemode
Your first step should be to put the XP CD into your computer and try to perform tasks from the Recovery Console. I'd suggest a "chkdsk /r" and maybe even a "fixboot". If those don't allow you to get back into windows then try to do a "repair install" of Windows. This is just a temporary measure, to recover any files you don't want to loose. A repair install is a very unstable reinstall of windows, basically installing windows ontop of your current windows install. It can result in the computer crashing again, so should not be relied upon. Once you have all your data backed up I would suggest a complete reformat of the computer.
Jan 03, 2014 | Dell OptiPlex GX620 PC Desktop
System disks startup
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Slow computer
Corrupted System Files
Your computer slows due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer slows.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer crashes due to problems with the computer memory. A faulty RAMmay result in Blue Screen of Death (BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer slows because of apreviously failed or incomplete installation. An incomplete or failedinstallation creates junk registry entries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer slows if the operating system has no adequate free disk space toperform its operations. Temporary files, temporary internet files, log files,browser cache and other files may occupy a large amount of your disk space andthus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
Mar 10, 2011 | Dell OptiPlex GX620 PC Desktop
Having had my sons laptop crash with the message bootmng missing he installed windows vista for a medion laptop on his toshiba C650 laptop but now i have read that we could have it with original software...
if you have the windows vista dvd then put it in, boot from it but when it comes to install step , check for the REPAIR SYSTEM option at the bottom,
select that option and choose -> startup repair.
follow onscreen steps and wait for system reboot.
if everything goes fine it will start but if this doesn't work then you'll be needed to reinstall the whole OS..
Mar 01, 2011 | Computers & Internet
Windows Installer issues with Desktop Maestro
Your issue is a permission error in your registry with the files associations trying to be written at install. I had the EXACT same issue with Acrobat. Search the internet for "Acrobat Installer Issues". There is a link at the abode fourms site to Download a program to reset the entire registry permissions. As you will NOT be able to do this, Windows will tell you, "you do not have permission to view the permissions. Although you do NOT have Acrobat problems the issue is IDENTICAL.
Mar 27, 2009 | Computers & Internet
Computer start up problem
Capture the message that is displayed on the BSOD. There will be a bunch of numbers that will tell you what is wrong. I would open the side and re-seat the RAM and do a general cleaning of the fans.
Mar 16, 2009 | Acer Aspire m5640 PC Desktop
IBM Lenovo Desktop Won't Start Up
when the computer is booting up hold F8 to go to the windows advanced options menu it will give you options to boot from last known config as well as safe mode
Feb 05, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Encore PC Tools Desktop Maestro 2008 for PC (705381141501) Logo
77 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
