Question about Homelite ZR10926 16 Chain Saw
Homelite chain saw fuel system
My Homelite chain saw will not start. It appears to be a fuel system problem. When I looked in the fuel tank, the fuel filter had fallen off and there were to open lines. i do not know when these go, and which line gets the fuel filter. Any help, Thanks.
    Brigadier General:
  • 4,088 Answers
The line at the back of the tank gets the filter (check it for plugging) and the one nearest the cap doesn't use a filter (it is the return line from the primer bulb). The filtered line goes directly to the carburetor inlet port and the outlet port allows fuel to be pulled through the carburetor and out to the primer port. Check and replace any fuel lines that are in poor condition. If the engine has been running with the intake filter missing, the interior of the carburetor may be full of debris. Remove, dismantle, and clean the carburetor interior. Go to: http://www.drystacked.com for an excellent 12 page article on Walbro carburetor theory and troubleshooting. Hope this helps!
Posted on May 31, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
My 46cc Homelite will start & idle with the choke on, as soon as I push in the choke it reves up by itself then cuts off
This is fuel starvation, start by removing and replacing the fuel filter in the fuel tank, check the fuel hose up to the carb foe signs of leakage, replace hose if required.
Aug 21, 2011 | Homelite FactoryReconditioned ZR10522...
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
I have a homelite super 2 chain saw. when using it at an angle fuel is leaking from the tank. i removed cowling and inspected tank. there appears to be a factory hole in the top of the tank. is there a...
Homelite uses a porous bronze plug in the tank case for a vent. Any open holes should have fuel lines in them--one to feed the carburetor and which has the fuel filter in the tank interior. The other is a return line from the primer bulb that allows fuel that is pumped through the carburetor, into the primer pump, and from there return the pumped excess back to the tank. Be sure to use original rubber lines for replacement, not plastic. Hope this helps!
Jun 23, 2010 | Garden
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 27, 2010 | Homelite Garden
Homelite chain saw quits in 15 minutes
Why are you not standing on the help desk where you purchased this? If it starts to sputter then dies It is probably a plugged fuel tank vent. When it begins to act up roll the saw so the fuel cap is up right and loosen it a little. If it smooths out and runs correctly you just vented the tank and that is where the problem lies. If it suddenly stops running with no warning it is most likely an electrical problem. If you repair either of these problems it may void your warranty. Why not make Homelite repair or replace it? If offered a refund I would not purchase any product by the same manufacturer. At best their quality control is lacking. HTH
Lou
Nov 23, 2009 | Homelite Garden
I try to start the dx3300 chain saw but not start look like fuel isn't go to spark
No-fuel problems are the result of bad fuel lines from inside the fuel tank out to the carburetor. If lines look good, rebuild the carburetor itself to repair hard, cracked diaphragms and varnish build-up. If carburetor is a Walbro brand, go to: www.drystacked.com for a 12 page PDF on theory and repair. Good stuff!
Oct 11, 2009 | Homelite ZR10926 16 Chain Saw
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Homelite ZR10926 16 Chain Saw Logo
596 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
