Question about Waterway Above Ground Hi Flo Pump
Pool pump only makes a buzzing noise when plugged in.
Above ground pool pumps only makes a buzzing noise when plugged in. All hoses are connected and plugs removed. Having trouble taking the clear cap top off pump to remove air in pump.
  • 8,404 Answers
I think one of two things is going on ...
a) you spun the impeller. You say you have an air bubble in the strainer basket ... you probably also have air in the filter. When this condition exists ... and when you turn the motor off, the air, under pressure, wants out so it spins the motor in the reverse direction. If you turn the motor back on before the motor stops free turning backward, the the jolt spins the center out of the impeller. If you turn the motor off, you should always wait 15 seconds (maybe longer) before turning the motor back on. Listen to the motor. Also be mindful of the air in the filter, bleed it off when you find it ... seal the places where air can get in on the suction side.
The same thing can happen if you experience a quick power failure ... power off for a second and right back on. It is no-bodies fault ... just happens.
Remove the motor from the pump body. Remove the back cover on the motor. loosen the start capacitor so you can get a open end wrence on the flats of the armature. Remove the broken impeller with channel lock pliers or similar.
b) the start capacitor may have failed. To fix this, find the capacitor in the back of the motor. Replace with the same. Purchase from your pool supplier.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
I have a 15,000 litre above ground index pool with three openings and a Krystal clear 638R filter pump with three hoses how do I connect them
in is front hose of pump to skimmer top back hose of pump to in of filter out of filter to return of pool
Nov 16, 2016 | Pool & Spa
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
How do i clean and backwash my krystal clear saltwater system model cs8110 pool. Also it is very cloudy and I cant see the bottom of my pool
Hello... Is this your first pool? If so, do you have a local pool chemical supply company? They will test a sample of your pool water with way better equipment than the test strips... Than they will tell you exactly what you need and how to apply them... This is my 4th year with this salt system and 18'x 4' intex pool... Starting them up is tricky and it still takes me weeks to get it right... But the pool store told me how to start it up for next year so hopefully it won't take as long...
The phrase backwash referes to cleaning the filter... With the intex filter/pump system, that is the filter cargtridge that inserts into the pump/filter housing... Close the pool valves, open the filter cartridge housing, take the filter out and hose it down with a garden hose... Before you return the filter, dump out the nasty water sitting in the filer/pump housing... the Return the filter, screw back on the cap, open the pool valves and open the vent screw on top of the filter cartridge housing lid... This allows the pool water to flow back into the filter/pump and removes unwanted air pockets in the hoses... Once the water flows out of the vent screw, screw it back down to stop the water coming out... Now your down backwashing the filer...
Hope this helps,
Dan
Jul 13, 2014 | Intex Automatic Salt Water System for ...
Emerson 1081 pool pump makes buzzing noise when i turn it on wont start
Either something blocking the impeller / shaft, from turning or the motor failed.
You can try to manually assist the motor, by removing the small cap at the back of the motor, getting a flat blade screwdriver, and right when you flip the switch (get a helper) turn the shaft clockwise while it buzzes. If it takes off - possible Bad Capacitor? Try a couple times if it doesn't take.
if bad capacitor, make sure you get the exact replacement, or 'Slightly Greater' will work - and I refer to the MFD number. Don't go smaller!
May 29, 2014 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
I have a krystal clear 635T filter pump that we got last year with an easy-set above ground pool. We just set the pool up for this year and are having trouble with keeping the filter under the water. ...
There is still air in the hose.....get all of the air out by holding it under the water completely or by filling the hose with a garden hose...
heatman101
Jun 28, 2011 | Sport & Outdoor - Others
The machine moves but the fan does not turn, the motor is humming
Occasionally hair or linen may get caught in the impeller. If that happens, take the top grill off by removing the 2 screws from the top. Make sure that the transformer is unplugged. Remove the debris. Replace the top grill and tighten the 2 screws. This is most likely what is causing the trouble with this automatic pool cleaner.
Aug 28, 2010 | Smartpool Dolphin Robo - Kleen Above...
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Waterway Above Ground Hi Flo Pump Logo
666 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
