Question about Polaris Pb4 - 60 Booster Pump
Pump Cycles on and off. Runs for 10 to 15 seconds then shuts off for a period and repeats the cycle.
  • 8,404 Answers
Is this motor thermally protected? Are you running it on 240 VAC and the pump is set up for 240 VAC? (120 VAC- and 120 VAC?). Pump is on its own circuit, or one adequate to supply the proper volts, amps and watts? No extension cords involved?????????
The motor does this because it is over heating for some reason ... improper voltage comes to mind.
You say it starts but will not run ... a faulty run winding comes to mind (start circuit is evidently ok)
Overheating can als be caused by an obstruction in the suction or discharge ...
Posted on May 31, 2010
  • A Miller May 31, 2010
    Thanks for the 4 thumbs up ... what did you find out?
    Thanks for your interest in FixYa.com
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Goodman a42 15
A high temperature operating thermostat will cause a problem like this. Limit switches need to be reset, but operating stats don't. Be sure your blower fans filter is clean and the ducting and path up through the furnace is clear. Stay in touch. Roger
Dec 16, 2013 | Heating & Cooling
Pool pump cycles on/off
What is it? do you have a pic?
Jul 20, 2013 | Pool & Spa
Heat Pump cycles on and off repeatedly
change battery in thermostat and inlet air filters in house real cheap to do
Feb 29, 2012 | Heating & Cooling
Car wont hold pressure in fuel lines..
YES..IF YOU DON'T WANT TO REPLACE THE PUMP ,,YOU COULD TRY CYCLING THE PUMP 2 OR 3 TIMES BEFORE YOU CRANK THE ENGINE..REPEAT KEY ON..PUMP RUNS 2 SECONDS ,,,KEY OFF .YOU CAN USUALLY HEAR A SLIGHT WHINE FOR THE 2 SECOND PERIOD
Mar 20, 2010 | 1996 Oldsmobile Achieva
Defrost cycles needlessly for extended time period
Without knowing what the problem was with the old board, you're not going to be able to figure much out, I don't think.
Did you check that temperature sensor I mentioned? You will have to pull the top off to get access to it. Normally found connected to one of the tubes for the coil, silver in color, with 2 wires connected to it, near the bottom of the base of the unit.
Dec 13, 2009 | Heating & Cooling
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Polaris Pb4 - 60 Booster Pump Logo
612 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
