My garage door opener key pad.
i put a new battery in 2 times and the battery is drained within 2 days. what could be causing this to happen?
Some feature on your opener must have a switch that is stick in the closed (on) position. Possibly, you put a near dead battery into the device? Please check with a volt meter.
You could check the device with a volt/ohm meter in the circuit ... put the meter between the + post of the battery and the + contact of the device. Put a wire on the - battery and the - device to complete the circuit ... if you are using power, there should be some amp reading on the meter.
