Question about Cameras
I have a JVC digital video camera GR-D93U which I cannot use due to an E03 error. I have tried many times,taking out the cassette and re-inserting it but get nowhere. I have taken it back several times to the shop where I purchased it but they say they cannot help me.
    Genius:
  • 1,142 Answers
Http://www.howtomendit.com/answers.php?id=14372
Try this link
Posted on Apr 08, 2008
  • Anonymous Apr 08, 2008
    press the record button and hold, then press the manual focus button, and release both, that's works for me.
    Good luck!!
    The unit head cleaning is required too use a sony head cleaning spray open the deck craddle and spray it on the shiny head this will resolve the issue too.
  • 790 Answers
Hello sir,
E03 error means No Supply Reel rotation
6ya staff
SOURCE:
Have a JVC GR-D72U video camera. A E03 indicator keeps coming on and it goes into safe mode. What can be done? How can it be fixed?
This problem mostly happen due to defective cassette, by ejecting it, it will solve your problem. If your tape stuck-up inside, apply power, open cassette door, keep it open (around 5 sec) until it opens. and try with another cassette. It must work if not, expert are needed in this case. Good Luck
Aug 30, 2010 | Video Cameras
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Getting error "E03 unit in safeguard mode" on JVC GR-D200U video camera
to the mechanism.
Nov 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Eo4 error
hi a malfunction of some kind has occurred in this case the camcorders functions become unusable. -eject the cassette once and re-insert it - it claers up yoy sould consult your nearst jvc dealer. good luck
Apr 07, 2006 | JVC GR-DX25 Mini DV Digital Camcorder
Cameras Logo
77 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
