Question about Bosch SHE4AM06UC 24 in. Built-in Dishwasher
My dishawasher is clogged with water in the bottom & it's not cleaning properly. What can I do?
  • Bosch Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Dishawasher does not clean dishes
Most of the time your nozzles are clogged or the drain in the bottom is clogged. open up the empty dishwasher and do a thorough cleaning. I am assuming that it is functioning normally, except the dishes are not clean. also use a good detergent and conditioner.
hope this helps
Jan 09, 2012 | Dishwashers
After dishwasher run through it's cycle, the water does not drain properly and remains in bottom of the dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 10, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
My dishwasher is not draining off the water properly. It has flooded the kitchen once already. I can here the pump running, but it is a bit noisy. The bottom of the dishwasher is still full of water after...
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Frigidaire Professional Series 24 in....
After the wash cycle is complete, a bunch of the soap is solidified and stuck in the soap drawer. And soap is smeared on some of the dishes. we are using cascade automatic dishawashing detergent. thanks
Greetings,
there is no water spraying into your soap area to wash it out...make sure the spray arms are not clogged..look to see if the holes in spray-arms are open, if not open them up...now , if okay, its possible little or no water is coming in...start d/w and see if water is entering tub. if so, its possible wash motor is bad just not spraying the water. clean out and sump area or screen.consult your manual for info on how to clean out if needed...if ok, check to see if wash motor is coming on..if it is then its defective and not moving water to sprayers
Oct 11, 2010 | LG LDF6920 24 in. Built-in Dishwasher
Display says "brewing" but no water gets pumped . Full reservoir, tried cycling power to the coffee maker twice but no sound. K-cup properly placed, System 14 mos old.
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Aug 16, 2010 | Keurig B70 Coffee Maker
Water does not come out when in spinning cycle. the tub just turns and turns but the water is not draining properly or better yet, it does not come out at all.
Sounds like aproblem with the drain pump.
could be a loose or worn belt or the pump could be bad. Giving directions on how to correct is impossable for me not knowing what type of washer you have. On some top loaders if you tilt the washer backwards you can see the pump & belt and check them.
Hope this helps
Please leave feedback
Nov 16, 2009 | Cars & Trucks
My dishwasher is keeping water at the bottom of the washer and will not drain entirely How do I get into the machine to possibly clean out ay food trapped?
Try running the garbage disposal, most dishawashers discharge into the disposal.
After that, try running hotwater through the disposal (with it off) for 5-10 minutes to flush out any grease.
Then, run dishwasher again.
Sep 08, 2009 | Dishwashers
Sprayer arm is not spinning, water comes up through weakly.
your water supply is too low. he watervalve (inlet valve) may be clogged. With insufficent supply you get a low fill and not enough water to fully enage the pump's power.
Apr 08, 2009 | Dishwashers
Won't drain water out?
Regardless of the brand, all dishwashers operate on the same principles.. in this case you said you checked for clogs and there are none..however.. have you checked the fileter screen for the drain, the hoses to the pump, the pump itself, the exit hose off the pump, the drain hose coming from the dishawasher to your house drain and is your house drain restricting water flow? Also.. is the pump actually operating at any time? These are the funadamental items to check..any one of them can cause your dishawasher to not drain properly. Hope this helps..
Sep 21, 2008 | Kenmore 24 in. 17594 Built-in Dishwasher
Bosch SHE4AM06UC 24 in. Built-in Dishwasher Logo
77 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
