Question about Philips 52PFL3603D/27 52 in. LCD HDTV
Picture wont come up on TV just the sound, i tryed unplugging everything and plugging it back in.
  • Philips Master
  • 8,457 Answers
Ur tv the LCD inverter board is dead.Replaced this inverter board ur tv will get the picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 31, 2010
Drummernick
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
ramon49
  • 111 Answers
SOURCE: sound but no picture
You popped the plasma HV generator. Do you use a UPC all the time, if not then power line surges or brownouts can cause this type of problem. Needs Pro shop repair, expect around 450.00. PS: buy a upc for around 10 minutes run time $80.00 ??
Please rate!
Posted on Mar 31, 2009
rulds2008
  • 3866 Answers
SOURCE: blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 21, 2009
  • 10 Answers
SOURCE: 50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Posted on May 11, 2010
My tv has sound but no picture
Try this:
Unplug it and everything plugged into it.
Hold the power button with it unplugged, then plug it in whilst holding the power button.
Hold the power button down until something happens.
This might reset the tv
Apr 05, 2017 | Televison & Video
The screen is completely black. you can hear sound but the screen is still black.
Try unplugging everything then unplug the TV for a minute plug everything back in turn on. It might be the main board that needs replaced on it if that wont work. FYI LCD TV/ DVD Combos have been known to have issues
Jan 27, 2011 | Proscan 32LB30QD 32 in. LCD TV
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
you might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Oct 08, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything...
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Apr 13, 2009 | Westinghouse LTV-37w2 HDTV
No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Feb 12, 2009 | Sanyo DP32746 32 in. LCD Television
XBox has no picture
try and have your video cord check..probably your console is working normally as sound is ok..no video signal reaches your tv set...pagadian
Aug 03, 2008 | Microsoft Xbox Console
** sound! Please help
I'm not sure about 10 seconds but its been unplugged and plugged back in and the darn thing still wont work.
I will try it
Thank you!
Mar 10, 2008 | Philips 27PS55S 27" TV
Philips 52PFL3603D/27 52 in. LCD HDTV Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
