Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have a sailboat with a 9. outboard should the motor be moving as I steer with the tiller?
  • 59 Answers
Normally with such a set up you increase the steering friction adjustment till the motor is to all intents and purposes locked solid.
I don't recommend having it moving if you can stop it .
Posted on Jun 03, 2010
I have a 2000 mercury 40hp outboard , does this motor have a fuse inside i can replace, no power to ignition, or tilt,
if ignition attached to a dashboard fuses in behind dash board. should be marked. if motor is tiller steering then the fuses are inline or tucked in housing. back track from problem.
Aug 26, 2017 | Mercury Boating
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Dec 16, 2015 | Boating
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Outboard troubleshooting
If you take her out of the water and clean off the flotsam, it may become apparent where the issue is.
Aug 01, 2017 | Boating
Outboard is locked to one side , can't find the catch to release it,
In The Middle Of The Engine Just Below The Cowl Is A Small Lever
Move It Counter Clockwise To Release The Co Pilot
Mar 15, 2013 | Boating
Do outboards by johnson have a lock for the outboard steering. my steering will not move but it is not the teleflex cable as tghat moves freely. it appears to be locked on the other side to where the...
If the motor has been sitting it might be siezed by rust. There is a greaase fitting on all outboards to lubricate the shaft that it turns on. Look under the head near your transom and it is probably there. I am thinking this may be your problem.
Mar 13, 2011 | Garelick S.S. Motor Bracket for 2-Stroke...
My Ray Marine ST 1000 auto tiller pilot started setting stuck, but not consistantly. the shaft just vibrates in some spots but does not move. what could be the probable cause?
the worm gear that is inside the unit may need to lubricated,, remove the bottom case and lubricate gears and shaft with a teflon or silicone based lube. also on my sailboat when this happened I found that I needed to re-calibrate the unit - take the boat out into a very calm and open water and ' spin the boat ' in CAL mode ( this will re-orientate the internal compass ).
have fun on the water and have a great night,
c...
Jan 06, 2011 | Raymarine St1000 Plus Tiller Pilot
Moving the steering from aft to forward on a runabout
There are a couple of options. If you forgo the steering wheel I know that Johnson and others make a Tiller extender. I have been able to move up a seat in a 12 foot boat using this. On my motor the speed control was on the Tiller handle. Still had to jump back to use gear shift.
The oldstyle controls used 2 cables and pulleys to steer wheel. You will have a time to find short enough cables to do motor RPM and shifter. Then you will need to mount steering wheel to something to turn it.
There are Salvage yards for Boats just like there are for cars. Do an internet search for your area. Then pull your boat there and explain what you want to do. Look under Marine Salvage, Marine Salvage yards.
Mar 07, 2010 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
162 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
