Question about Lexmark X1270 All-In-One InkJet Printer
Printer won't print! Holding several documents in
Printerwon't print! Holding several documents in queue. Printer is on and everyting is connected properly but no response.
  • 8,404 Answers
Delete the documents ... delete the printer ... reboot ... reinstall the printer.
There is a possibility you cannot delete the documents and there is a possibility you cannot delete the driver ... if that is the case ... install a second copy of the driver.
Posted on May 31, 2010
How do I cancel documents in a queue
Cheers james heron
To cancel a queued document, there are several ways, it is best to go to printing devices and open what is printing the printer you want to cancel, click Cancel and disappear the document.
In many cases this does not help then you click cancel, the document continues to appear, that's when it works best to turn off the computer and turn it on again.
Another thing you can do to disappear a file from the print queue, disconnect the printer's USB cable and connect it again, for it can do so from your computer or from the same printer.
Another way that can work is, turn the printer off and turn it on again, you should always look the team to lose the memory of what is printed, in order to begin again.
How to delete documents in my printing queue en Rellenado
Nov 23, 2015 | Office Equipment & Supplies
How do I restore connection to my printer. I was in the middle of printing a document and lost power to my PC. Now cannot print Many thanks. Brian
Go into your computer printer set-up and check if there are any jobs left to print. Check manual or tech support. Maybe youtube has video on it.
Mar 17, 2015 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
Dell v515 printer
Several immediate things come to mind; check to make sure that the printer drivers are up-to-date; there maybe a possibility of an IRQ conflict; check to make sure that the printer is set as the default printer in control panel; make sure that the printer you want to print from in the <file>, <print> menus screen is selected and not a virtual one. Absent more info like OS and how your printer is connected to your computer (e.g., is it through a serial cable, then make sure com port is active in BIOS and is checked off in the properties menu [control panel, printer, properties, port tab]; or are you using an LPT-printer port or USB connection- make the same check. Sorry that I can't be more specific without additional info.
Nov 22, 2013 | Office Equipment & Supplies
My 9500 series Lexmark won't print, computer says its not communication
1. Check your printer to be sure your printer is listed as installed
2. If the print queue is full it can become confused and just hang up so turn off the printer to empty the queue
3. Power up the printer and send one document to print as a test
4. If the printer works, you should be back in business
Jan 20, 2013 | Office Equipment & Supplies
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
I have a document in the memory of my Cannon MX300 Printer and can't figure out how to clear it. I have tried pressing the pause/reset button but to no effect. Help
You can clear the printer memory by switching of the power and unplugging the printer from the mains socket. The problem may actually be that the Windows print queue is holding on to the document, in which case you need to remove the document from the print queue on you PC.
Mar 24, 2011 | Office Equipment & Supplies
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 18, 2010 | Epson Office Equipment & Supplies
DOCUMENTS FOR PRINTING DON'T GO INTO A PRINT QUEUE
If you mean that when you go to print a document it doesn't hang in the Windows print queue and leaves quickly, then it is because either the printer has grabbed the document into its memory or it has sent the document to what it thinks it another printer. It might also be that the drivers you are using are not set correctly or that the connection to the printer is incorrect.
Jul 09, 2009 | Lexmark E232 Laser Printer
Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
Jun 07, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
