I have a 36 inch samsung tube television. i had some kind of power surge and it shut off and that was it from there.The T.V. doesn't turn on anymore. Is it worth fixing? what could be the problem? thank you
  • 8,617 Answers
Could be a fuse or regulator fried. With this type of repair I suggest an experienced tech unless you are comfortable working around electrical voltages some of which can be dangerous.
Posted on Apr 08, 2008
Samsung pn50c450b1d had a power surge doesn't turn on
if able examine the power supply board in the set, if not able consider having a repair shop look at the set.
Aug 26, 2012 | Samsung PN50C450B1DXZA - PN50C450 50 720p...
Sony Wega 32 inch tube TV buzzes when turned on and then shuts itself off. If you turn it on several times the picture will stal on
look likes E H T problem. Watch the rear of the TV. If you find blue arc anywhere, you have to check that component. Take care while handling the E H T side near the picture tube.
Even if the TV is disconnected there me dangerous voltage present in the E H T connecting point of the picture tube body. Take service center help.
Apr 07, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
2003 Sony Trinitron 36" television. Just shut off, light blinkin
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Help me fix my 60 inch projection samsung
try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Jul 25, 2008 | Samsung HCL4715W 47" Rear Projection...
36 inch 36v430t
It's simply refered to as the power supply- the repair guys will know exactly what you are talking about when you use it. You see the power supply upgrades the power to drive the tube- much in the same way a coil increases the power on your car from 12 volts to what ever it needs to turn the engine. The green light just means that you turned it on, and all the other curicuts are working. Like if your car coil is bad-you can still turn on the lights and radio-but there is not enough power to turn over the engine/turn on the picture tube. I love my 36 incher- mine is 12 years old-and was only in the shop once-and still gives a better picture than the LCDs out there. I'm a member of SMPTE. society of motion picture and television enginers.
Jul 02, 2008 | RCA F36650 36" TV
Sony 36" Trinitron Problem
Good day.
There may have been some problem in the horiontal transistor. Also, Check for the zener diode that controls the supply going to the flyback. It might got busted due to the sudden supply surge.
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Proscan 36 inch tv
Good day.
The spark the you see means that your wall socket is loose. Have it fixed by a qualified technician. With regards to your unit, it has an internal problem. In my experience, the power supply is not dissipating power to the circuitry. The problem is contained in the power supply, have it checked by a technician.
Mar 04, 2008 | Proscan PS36500 36" TV
Sony 36" Trinitron
The power supply section is having trouble.
Common possibilities are:
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 22, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Televison & Video Experts
