We have ajd model 3235c fairway mower error code blinking light rear back lap s the reels will not backlap or now rotate at all larry
  • 3,247 Answers
Please follow the error code descriptions in this document
http://manuals.deere.com/cceomview/OMTCU22129_A6/Output/OMTCU22129_A66.html
to confirm the problem. I am not able to understand the actual error from your description.
Please post a comment if you have a more detailed description of the problem.
Posted on May 31, 2010
  • Sam Jun 07, 2010
    Would be happy to help on this problem if you have not worked out the message relevant to the error you have noticed. I had sent you a copy of the manual.
  • Sam Jun 10, 2010
    Please post a comment to confirm if the error codes I sent have been helpful or not.
We have a john Deere 7700 fairway mower 18 months old on the fairway ends when turning in reverse the rear wheels scrub the grass and leave marks on the grass more so when grass is wet also last week 4 WD...
What you have is a locked up differential. The rear axle will have to come off, and be disassembled to see what is wrong. Or, if it has posi-traction, the lever that applies the pos-traction could be stuck.
Nov 03, 2014 | Garden
How can I fix the fact that my reels on the front of my fairway mower are not cutting like the back reels
check to make sure there all sharp if there dull they will cause the problem
Sep 22, 2014 | Garden
Why is my handycam beeping c:31:23 when I turn it on?
Dear Friend,
While asking your query you should have given full information regarding your product like: Brand Name ( Sony; Panasonic; etc) Model :( DCR-HC42 etc) and more description of the fault.
From your question I understand that you have a Sony handycam and it gives error massage of C:31:23.
Sony has defined Self Diagnostic code for each product. According to which your handycam has Supply Reel Fault ( Try using other cassette, if it is resolved ). This code is generated when the supply reel is not rotating while cassette is loaded.
If supply reel is rotating and still you see the same error code, the there are chances of :
  1. Problem with reel sensor of camera
  2. Problem with End sensor of camera
If problem remains unsolved, best thing you contact nearest service center.
Dec 24, 2010 | Cameras
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Sep 22, 2009 | Garden
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Mitsubishi rear projection HD1080p tv model # ws-48311
press in the menu and input/device buttons both in together on the TV and hold in for 6 seconds to see if the led will blink a two digit error code then let me know what the code was.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Error F01 and F02
Both of these error codes are related to the reels inside of the camcorder. The error codes that you mention stand for No Take Up Reel Rotation (F01) and No Supply Reel Rotation (F02). The take up reel is the one that pulls in the extra slack while the tape is running so that the tape itself does not become loose and choppy. The supply reel is the reel in charge of turning to allow the tape to unwind. What you are experiencing are both common reel rotation errors.
First things first, restore your camcorder to factory settings, take out the battery and leave it out over night, plug it back in the next morning. If that doesn't fix it, try a completely different tape that you've used in the camcorder before to see if there is something wrong with the tape reels (sometimes they are loose) or the tape itself.
If that does not work, your next step is cleaning the camcorder. Use a cleaning tape. You may want to perform two or three cleanings in order to make sure that the camcorder is back to normal. You can also use an electronics dusting brush and manually clean out any visible dirt or dust, sometimes blowing cool air (such as the canned air used to clean computer keyboards) directly into the camera can fix the problem as well.
Unfortunately, if neither of these solutions fixes it, it's time to take it to a repair shop, it may need a new reel mechanism inside of the camcorder.
Mar 30, 2017 | Panasonic PV-DV710 Camcorder
Computers & Internet Logo
David Payne
David Payne
