Question about Garden
Husquavarna 125 l weed wacker only runs on full
Husqvarna 125 l weed wacker only runs on full choke?
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets, but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, turn the screws in to seat them and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 31, 2010
My husqvarna 123L weed eater will only run on full choke I bought this way and person before played with carb settings. I rebuilt carb now want to get factory settings
check how the carby was put together as the problem is a blocked main jet or diaphragm not working properly
it is sucking fuel in on full choke but the jet is not allowing fuel in to keep running
Jun 25, 2015 | Husqvarna Garden
My hmc green machine 3000ss weed wacker carb needs adjusting it only runs with choke closed
Try cleaning or changing the air filter. If it dirty the engine will not stay running with out the choke on.
Feb 17, 2014 | 2010 Vuka XL 125
Primer bulb will not prime
Hello Tony Galvan, I had to replace the fuel lines to keep from sucking air when I pressed on the primer bulb. Also, I took the carburetor apart and found the gasket was good by holding it up to the sunlight, no light came through indicating holes in the gasket. Then I took a magnifying glass and looked at the bottom half of the carburetor and noticed that a soft film of what looks like lint from a dryer had accumulated on a screen mesh type of filter. Once I cleaned the debris away, the weed wacker started every time. I pulled with a full choke and partially wants to start. Then moved the choke to half choke and pressed on the throttle fully and pulled, it started! But you must at least hold the throttle close to full until 10 seconds for the engine to warm up. Then move the choke to idle. Hope this helps.
peterjb1
May 29, 2013 | Weed Eater SST25CE Gas Trimmer
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
Never used weed wacker before I have a Echo SRM225 how do you start the darn. thing..? :) I have pulled and pulled and no I am not out of gas. :)
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
May 20, 2011 | Echo Garden
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
