Question about GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque
Freezer seems to have stopped working on my Model GSS25JFMD.
A few days ago we noticed water dripping from the bottom of the frig. I checked the freezer today and observed the items in the freezer from top to bottom were in varying degrees of frozen from thawed on top to semi frozen to frozen on the bottom. I am thinking things were gradually thawing as the temp in the freezer dropped.
Is there any kind of system check, diagnostic or cleaning of coils, etc. I could do? My next step is to check behind the frig and see if anything is dust clogged. Also, right now I turned up the freezer from 3 to 9 and placed a baggie of water on the top shelf to see what is happening.
Our side by side hasn't ever given us a bit of trouble. I think we purchased it in 1998 or 1999.
Dan
  • GE Master
  • 1,606 Answers
From your description , it sounds like the fan in the freezer quit working . This is usually caused by the main control board behind the refrig , behind the 8 X 10 " panel . It would be adviseable to replace the freezer fan motor also as this could have caused the board to malfunction .
Posted on May 31, 2010
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFreezer seems to have stopped working on my Model  - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
795.79309.901. Why is water dripping from hole on bottom back right of digital temperature control?
Drain is possibly blocked inside freezer that allows water to escape to the pan below the refrigerator. You will need to remove frozen items and remove the panel that covers the evaporator to get to it.
Leaking Refrigerators
Appliance 911 Sea Breeze
Sep 17, 2015 | Kenmore Refrigerators
My kenmore refrig (freezer on top) has started dripping from tube near temp control inside of frig. I think it might be related that one month ago - electric was off since not at apt for one month. Doors...
Your defroster inside the fridge may not be doing a good enough job to keep the drain from freezing up. Check to see if the drain pan is frozen over in the freezer section. I took the cover off the inside of the freezer and wrapped a piece of uninsulated 14 gauge solid copper wire around the heating element and pushed one end down the inside of the drain tube and wrapped the other end around the heating element. No problems since.
Aug 16, 2013 | Kenmore Sewing Machines
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque Logo
139 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
