Question about Kenmore 62602 Electric Dryer
Kenmore dryer just stopped working??
Hi, I dried one load today without a problem then when I tried to do the second load the machine just stopped working. At first it seemed as if the push start button just popped back out and so I pushed it a few times then it just kind of died. The cycle button started making a low vibrating noise so I unplugged the machine for a while, fuses in house are good, anyone know what this means???
help!
  • Anonymous May 07, 2008
    Same thing happened to me. But I cleaned out the vent hose and vacuumed the vent duct to the outside and all is well again! Thanks!
Replaced thermal fuse and working like new
Posted on Apr 13, 2008
    Genius:
  • 1,073 Answers
Thermal fuse or the blorer limit is bad indicating that there is a restriction of air flow in the venting of the dryer, kinked vent hose,wallvent louver stuck closed or lint in the vent housing, bet venting issue
Posted on Apr 10, 2008
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
My son has a Kenmore top load electric dryer. It
Hi, Check the door switch and the fuse. The fuse is the most common cause. You can also let the dryer cool down for an hour and see if it will restart. If it restarts, the motor might be going bad. It is hard to say without model# I'm afraid. I have not heard of a top load dryer but, these are common things to check.
Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 66512690 problem
Appliances which use heating elements almost always have an internal overload protection switch. This overload usually looks like a small diode or resistor somewhere on your incomming power inside the machine. Try to find this overload and bridge it out and try the machine again. These overloads usually have a rather limited life span and are most often the cause of a "dead" machine.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore 65924 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore Elite Oasis Steam dryer runs but gets a F 40 code and stops. Just plugged it in to do my first load. Tried pulling out and checking lint in vent. It seemed to over heat the first time then sat a...
After just now calling the service center it seems that unplugging the machine for 30 seconds or so will reset the control panel. The F 40 code means the signal wasn't working in the machine and resetting it solved the problem. Kind of like when you have to unplug the computer sometimes.
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Very long drying time
ck vent system if vent not oper it can cause flame roll out and shut off unit also ckd flame sensor on side of burner
Jun 01, 2008 | Kenmore 73952 Gas Dryer
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kemore Dryer will not start
the dryer is almost 15 years old! the drum rotates on two or three felt bearings in front and a ball bearing in the rear. the belt may have broken, the tensioner may have loosened. the motor goes in one direction only and starts off a centrifugal start switch. If the motor doesn't get up to speed to open the start winding, the machine just won't go. check the belt first.
Sep 04, 2007 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
263 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
