Question about iLO (2 GB) MP3 Player
I need to remove write protection from my usb stick, how do I do this?
  • iLO Master
  • 19,396 Answers
Hi.
Check if the player has a lock switch on one side. In that case use the switch to unlock the player.
If there is no lock switch, then the player may need formatting. Before formatting , try performing the operations here: iLo Mp3 Player Help is Here.
In some case the problem depends on the computer. In that case you find indications here: ILO Write protected - FixYa
Posted on May 31, 2010
  • 5 more comments
  • jcondon58 May 31, 2010
    It is not an MP3 player, it is a USB stick and I cannot format it as it is write protected, so I need to remove write protection.
  • Ginko
    Ginko May 31, 2010
    Hi.
    Check if the USB stick has a lock switch on one side. If there is no lock switch, then the problem depends on the computer.
    Here is an utility to format a protected usb stick.
    If that does not work go to run->Type Regedit->search " StorageDevicePolicies" -->
    open Write Protected File and and change the value into " 0 ", click ~OK, then unplug and connect back USB memory stick.
  • jcondon58 Jun 01, 2010
    Repair_v2.9.1.1 came up with an error message - cannot find flash drive.
  • Ginko
    Ginko Jun 01, 2010
    Repair_v2.9.1.1does not work with all the USB drives in commerce. Before attempting anything else, ensure that the problem is not the computer. Try connecting or formatting the USB on a different computer.
  • jcondon58 Jun 02, 2010
    OK I will try it on another computer.
  • Ginko
    Ginko Jun 02, 2010
    Ok.
    Let me know how it goes.
    G.
  • jcondon58 Jun 03, 2010
    Tried another computer and still says it cannot find the flash drive. The computer recognises the flash drive ok.
My memory stick is showing write protected, how do i remove it, does not even wamt to format
hi thembi.
Go to My Computer and under Devices with Removable Storage look for your cardreader; right-click on it and click Properties. In the pop-up box, sometimes there's an option to Remove write-protection. Change the status of this option and try again. Remove your memory stick from the drive.
How to Format A Write-protected SD Card/USB Drive/Pen Drive ...
or go to this link and have a read up.
memory stick is showing write protected Google Search
Nov 17, 2017 | Electronics - Others
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
Jun 16, 2016 | Electronics - Others
Write protection
Write protection means you can view the information stored in it but you can't write and transfer the information to it.
For removing the write protection follow the below mentioned steps:
1. Right click on the USB stick
2. Go to properties and uncheck the read only or write only protection option.
May 12, 2013 | EDGE Tech Corp Edge Diskgo Mini - Usb...
How to remove the write protection in my USB stick flask drive?
Usually usb sticks don't have a write protect option. But some models that do have that option. Look for a small switch on your usb stick.
Hope this helps!
May 19, 2011 | Computers & Internet
My usb memory stick is write protected,how do i remove that?
The adapter has a tiny switch on the side opposite the notch near the pins.
The switch needs to be towards the pins, not away from them.
Apr 06, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
How to remove usb write protection with notebook
Are you having trouble writing to a USB memory stick and you get a message that the USB memory stick is write protected?
Some memory sticks have a small slide switch which you can select to write protect the data on the USB memory stick.
Jun 18, 2009 | Acer Aspire 4720 Notebook
PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
As you said that there is no switch to lock and unlock usb stick so if this is the case than download the file below
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
This will solve the write protect error definitely
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Mar 21, 2008 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
