If the radio itself is not recieving any signal, it is time to replace the radio. These are getting cheaper and cheaper in certain cars. When you go to replace it, the key to this is, purchase for around $20 the plug in harness. It gets **** connected to the new stereos harness and then plugs directly to the vehicles existing harness so you don't need wiring diagrams or screw with the lighting. You can be done in about 30 minutes even as a novice.
fuse is in the fuse box under the dash but to be honest the MK1 or first generation focus had radio problems. The easiest fix is to replace the radio with an aftermarket one.
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here: http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
sounds like a window lift motor, maybe try and bang on the door a few times while you hit the button, if that doesnt work you may have to take the door panel off and test the wires at the window motor
yes you need a code 4 numbers to get the radio to work but this isnt a problem as i can generate it for you only need the radio chassis number.central locking could be the boot lock njeed replacing they always 'play up and it stops the lot
