Computer My auto protect was fine and now it says is turnt of and i wont let me turn it back on , how can i turn it back on ? Help please !
  • 871 Answers
Hey charlotte123,
since your auto protect is off right now, have you already done liveupdate?
if you cant, please go to the website, and download intelligent updater.
this will help you get back the green check.
Posted on Apr 08, 2008
Unwrite protect a cruzer blade usb
yes there is a funtion that you will find some files are system files and are undeleatable because the computer wont work with out them so they are write protected
Dec 31, 2011 | Computers & Internet
How do you turnt he flash off the nikon coolpix 2200
You see the 'lighting' symbol at the top of the round 4-way switch on the back of the camera - while in the record mode, pressing the 'up' switch will cycle thru the various flash settings: Auto, Fill-in, Red-Eye reduction, Off.
On the Flash settings, turn it from auto to off
Hope this helped?
Feb 09, 2011 | Nikon Coolpix 2200 Digital Camera
When i turnt on my camra it says protected card how can i fix it
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 24, 2009 | Fuji FinePix S304 Digital Camera
Oven does not work- broiler does
You have a heating element out in the unit. This element is located in the bottom of the unit. Unplug the stove and take out all the racks. There should be one screw on each side of the element on the back of the stove (inside of the unit) take out the screw on eack side and GENTLY pull on the element and you will see wires conected to the element. Dosconet and replace the element. You might see that one wire is burnt and not conected. You might try reconcting the wire and testing the unit. If that is not the case then replace the lower element and problem solved. If you have any more questions feel free to ask and I will be happy to help. Good Luck.
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Aprillia 125 custom wont start , it trys but wont catch ..
hello mate ive had the same problem and bizzarly it turnt out to be that i needed a new spark plug i have just give some1 on this site this information and it turnt out to be the same problem its worth try
Aug 03, 2009 | 2005 Aprilia Mojito Custom 125
Vx724 just stops working
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 26, 2009 | ViewSonic VX724 17" LCD Monitor
My phone wont turn on
BECAUSE OF STRIPE PROBLEN PLZ CHECK THE STRIP AND INSTAL A FALSH SOFTWARE OK
Jun 15, 2009 | Nokia 6500 Slide Cellular Phone
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Turnt itself off and now it wont turn back on?
More that likely its a heat sync issue and your CPU and GPU need to be reseated. email dwdpcrepair@gmail.com for more information
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
My xbox 360 turns on fine but i have no image or sound appearing
The GPU chip inside the console has become faulty.
This is also usually down to overheating of the console , thus loosening the chip from the motherboard.
May 30, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
