Question about Exercise & Fitness
I have a v-fit PST-04 treadmill, model no DK 2510. When I switch it on and try and use it, it comes up with the Error Code E1 what does thos mean
    President:
  • 832 Answers
Most E1 codes are speed sensor or no belt movement.
You wil lneed to unplug your unit the remove the motor shroud then plug unit in most Motor Control boards have LEDs. First thing I would do is start the unit look down at the board one of the light should start flickering this is a signal being sent to the lower board from your upper console. This tells me that the upper console and cable connecting the upper and lower boards is working also notice if the drive motor moved if not then E1 will come up. Now turn your unit off then turn back on to reset , next manually push with one of your feet the belt you should notice another flickering light the faster you push the light will flicker faster this tells me that the speed sensor is working if not replace the speed sensor. Next procedure check the motor using a fully 18v drill battery or car battery which ever is handy connect the two motor leads usually red and black in some cases black and white to the battery, if the motor move at a speed of approx. 1 mph then you have a good motor if not you can have worn motor brushes or open winding the motor.
If the upper board and drive motor are good then the only thing left is the motor control board if you have a multi meter handy connect the lead to the two spades that motor lead came off of the press start you should get a DC voltage of about 5 to 10V DC if not replace the board.
Posted on May 31, 2010
Have a v-fit PST-04 treadmill, model no DK 2510. When I switch it on and try and use it, it comes up with the Error Code E1 what does thos mean
Posted on Mar 08, 2011
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
V fit pst 04 treadmill error e1
Dear Sir:
Hello, i hope you are o.k
Please check this:
Most of the time, the problem in electronic code: E001 with the treadmill is:
VSD(Variable speed Drive, microchip failure). You must call to the factory and return the PCB assembly for the fix the factory.
The reason is that they have the code in the EPROM, and only them can fix and this case.
In short a recomend that you call to the factory and proceed.
After that when you have fix it your problem, I Strong Recomend to buy and install a Regulator Voltage is cheaper about us$15,00 aprox.
Thank you in advance, and hoping that you resolve, sincerely. Blessing. E.CUADRA Managua, Nicaragua.C.A.
Sep 25, 2011 | Exercise & Fitness
My treadmill is showing an E1 error code, what does this mean?
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 07, 2010 | RTO Lifespan TR1000TV - TR1000 With A TV...
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Exercise & Fitness Logo
1,374 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
