Question about SanDisk 4GB microSD High Capacity Memory Card
Corrupted microsd card
I loaded my micro sd into my Nokia e72 and there is this message "memory card corrupted", i also tried to encrypt but it is asking for a key that indont have. What can i do to save stored info.
  • manuel_j_can May 31, 2010
    Thnks alot, i tried to conect it using a USB cable connected to the phone and it still doesn't recognize. Any other options? By the way, if I format it will I be able to keep any info?
  • 81 Answers
Well ry connecting it to your pc and format it!!1
Posted on May 31, 2010
How to remove write-protection on a micro sd card
  1. Connect the microSD card to a computer
    Use a memory card reader to connect the microSD card to a computer for formatting. In case you're using an SD card adapter, ensure that the write protection key is in the unlock position.
  2. Locate the card Right-click My Computer, and click Manage. Go to the Disk Management tab on the left pane, and locate your microSD card from the list of available disks.
  3. Format the microSD card Right-click on the microSD card's drive, and click Format. This eliminates all data, including corrupted files that cause write protection in storage devices
Nov 09, 2016 | Electronics - Others
I cant format transcent sd memory card
In that case the memory chip inside it has failed and cannot be repaired. The card is dead, junk it.
May 04, 2011 | PNY 2GB microSD Memory Card
I have encrypted my nokia e72 memory card , now I am not able to decrypt it .I have very important data in it and I dont want to loose it. Please help
Here is the link to recover the data from your memory card. http://www.recoverdata.in/recovery-data/memory-card-data-recovery-utilities.html You can save the file in another folder and format your memory card and attempt to repeat the steps you had done previously.
It could be due to a corrupted memory card. Hence i would recommend you to get a new one if the above steps does not work
Jan 17, 2011 | Nokia E72 Smartphone
2GB microSD Memory Card memory card is corrupted memory card is corrupted
If its corrupted then simply down load hp format tool software. its free google it and downlaod.
install the software and format the micro sd card it will work fine,
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
Micro SD Memory Card Corrupted
try using a tool called formatter it just replaces the 01010000 whatever codes all to 000000 this'll do the trick hope this helped u
May 01, 2010 | Nokia 6300 Cellular Phone
Where do i find the micro sd on the nokia 6300
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia
uses approved industry standards for memory cards, but some brands may not be fully
compatible with this device. Incompatible cards may damage the card and the device
and corrupt data stored on the card.
1. Remove the back cover of the device.
2. Insert the card into the microSD card slot with the contact
surface facing down, and press it until it locks into place.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
Unable to open to read micro sd in window mobile and pc
the problem with this memory card is that they can be easily damaged or corrupted, sometimes if you just insert it in-correctly or take it out from your card reader without doing the proper procedure of romoving the device, it can be easily corrupted.
try to clean the bronze part of the memory card , try to clean it with eraser the wipe it dry.It is not 100% solution but worth of trying
Nov 02, 2009 | SanDisk 2GB microSD Memory Card
I am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
Sep 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 4GB microSD High Capacity Memory Card Logo
539 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
