Question about Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition
Blue coating in filter from heater, copper?
I think that my pentair minimax 200 is adding copper to my above ground pool which is coating my pool DE filter bright blue. Chemicals aren't doing the trick for me. Has my heater been ruined or a part maybe?
  • 64 Answers
It sounds like copper is the culprit. This usually happens from dropping the pH too low. You may have added too much acid. Heavy use of low grade algaecides can cause this as well. One last thing to check and make sure your not adding chlorine tablets in the skimmer. This will also damage the exchanger in the heater causing blueing. You may want to try a sequestering or chelating agent. Ask about it at your local pool supply.
Paul
Posted on May 31, 2010
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Pentair minimax nt heater
its not sensing flame you have to look at the burners make sure all of them light. Many times spiders wil get into the gas jets, you can use a number 12 solid copper wire to insert it into the gas jet you will see it ,the flame sensor burner is not having a good flame
Apr 12, 2014 | Pentair Minimax NT Heater
Pentair minimax 200 m electrical installtion?
Don't know just what your asking but if you want to know where it comes from. Wire the unit from the timer for your pump so it wont fire without the pump. Be sure to check the voltage on the pump and the heater will need to be wired the same (110-220V) This will be done inside the heater at the transformer. You will find instructions inside the panel of the heater.
Jan 30, 2010 | Pentair Minimax CH Heater
Pent air pool filter
Buddy is this happening, after the pump turns off or during.. Need more info.. type of filter.. Sometimes the sleeves on the neck area of the panel. Where it mates with the manifold slide down, you will have a small opening. Might be from their.. Could be a hole on one of the panels. Do you have a push/pull valve or a multiport valve (to back wash)
Mar 10, 2009 | Pentair "Pentair" In Ground Pool Pump ...
Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition Logo
93 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
