Question about Intel D845GVFN Motherboard
My comp doesn't display at all
My computer doesn't display at all.i have tried changing the monitors but i never solved. i believe the problem is in the board but i changed the VGA card but it doesn't solve. please advice
  • Intel Master
  • 3,247 Answers
Is the boot sequence going through, ie, can you hear the hard disk thrashing when you bootup. If boot sequence seems to be OK then the problem might be the RAM.
If you have more than one RAM module, then just put in one at the first slot and try. If no change, then try the other one.
If only one RAM module, then you may have to try replacing it to see if there is any difference.
Please rate the solution if it helps otherwise post a comment.
Posted on May 31, 2010
Hi and sorry to have bother you......I have my computer connected to TV monitor.... Before it would show the two screen, the comp and the tv. I went to hit the number lock and i hit the Scr LK button by...
On laptops both the laptop LCD screen and the external video port can be toggled to show laptop LCD, external vodeo and bothe laptop LCD and external video.
You need to press and hold down the Fn key and one of the function keys that has the monitor symbol, repeated pressing this function key will toggle the video outputs.
I cannot advise you which function key works with your laptop as they vary between different laptop manufacturers.
Sep 09, 2011 | Logitech Cordless Desktop EX110
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
My Studio xps 7100 often freezes on startup. Also when coming out of sleep mode or when trying to start up, the monitor will not display picture. I can solve this problem by turning off the computer,...
Sometimes hanging on startup is caused by a network adapter hanging renewing a lease, this can be caused by corrupt drivers, not allowing the adapter to wake up, you could try updating those with the latest from the Manafacturers rather than from Dell... ie Broadcom or Intel depending upon your adapter.
I hope this helps, if you require further advice please ask, if this solves the problem please can you rate my answer.
Thanks
Andy
May 16, 2011 | Dell Studio Xps 7100 Desktop Computer (AMD...
The display is shrinked vertcally in the centre of my LG 915 monitor. plz help me out. Thanks
Hi nasirallahdi ,
If your display is shrinked vertically , please follow the below steps :-
  1. Check the settings button on your monitor , when you press the button you have multiple options coming up which includes reset option.
  2. Go to the reset option and select ok , so that your monitor is reset.
  3. If this does not solve your problem then it could be because of a incorrect resolution being set in your desktop properties , in the settings tab.
  4. To change the resolution settings you need to go to the display settings by finding the option on the desktop via right click and you can try changing the resolution and see if things get ok.
  5. If still the problem persists , then it could be a hardware fault which you need to get repaired via the manufacturer's warranty limit , if it has expired you will be charged for it.
  6. Most probably the problem is with the incorrect settings in the monitor panel , and i believe after you reset your monitor via the monitor panel , things would be alright hopefully.
Hope this helps ...:)
May 10, 2011 | LG Flatron 915FT 19" CRT Monitor
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen problem
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
Feb 23, 2006 | LG Flatron 995FT 19" CRT Monitor
Intel D845GVFN Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
