Question about HP StorageWorks MSA1510i/MSA20 (AD594A)
There only 2 disks of which their led are on. The other 10 disks led are turned of. What could cause this situation?
  • 31 Answers
Provably they are selected on the ACU
Posted on Aug 15, 2010
I installed a set of H13 LED headlights on my 2009 Dodge Ram 2500 The low beams turn off & on alternately. why?
the led lights are not compatible with the car electronics causing a over load situation
talk with an auto electrician as to what extra you need to add to fix it
May 08, 2016 | Dodge Cars & Trucks
Tip
Major hard disk Read ERRORS
Many people say that they have major hard disk Read ERRORS, and sometimes loose data, That is to die for, even some attempt suicide. :)
Any how There are few steps to be followed up in order to get your peak hard disk performance
1. ALWAYS CHECK YOUR POWER SUPPLY for right power that is giving to your hard disk , cause in some countries power failure or load shedding or power cuts are even more then developed countries so in those countries power supply can damage the hard disk , but according to my own personal experience Disk Read Error are found to be in SATA drives much greater then the old IDE hard drives
2. Always give the C drive volume less then other drive (c drive is in which windows is to be installed)
like for instance you have a 80 GB hard drive and
you have 4 drives C: D: E: F:
then give
10 GB to C:
20 GB to D:
20 GB to E:
30 GB to F:
it can be done when you are installing any OS , cause in this situation you have to create partition for these drives .
in that case due to windows files in contact to 10 GB the hard disk will be optimized.
3. Always De-fragment your DRIVES from time to time especially DRIVE C:
here is an image how can you perform that
4. Perform data recovery scans & automatically fix errors
when ever you get a read error go to any file
follow steps
(i) My Computer > drive c( or whatever your drive gets read error ) >properties
(ii) in tools tab click error checking (check now) button ,
then in sub menu check for check the automatically fix file system error
and also check attempt of bad sectors
then press start ......
it will take some time cause it completes 5 phases,,, ( i recommend this when you are free and not using any drive )cause even sometimes it takes a restart .
see if it helps you ... do vote
on Apr 03, 2011 | Computers & Internet
Led bulb blinking even turned
1. voltage problem
2. transformer problem
3. the problem of the LED bulb itself
4. not suitable on your original fixture.
it depends on many situations, and you can check this blog out for better knowledge of LED products
LED tipster Lighting EVER
Jan 17, 2014 | Sharp XR-10X Multimedia Projector
Wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Situation Not Resolved:
If the system still won't power on, the system and AC adapter will need to be repaired. To start the repair process, click here.
Wii Console Turns On, But Has No Power Light Situation:
  • The power LED on the system does not come on, but the system still powers on and plays
Information:
If the Wii Console is still working normally, it is likely that the power LED is broken.
This issue will remain limited to the Power LED, and will not get any worse.
Unless the system is having other problems, continue using the console regularly for a few weeks to determine whether this interferes with the enjoyment of game play.
If, after using the system for awhile, the Power LED not coming on is too distracting, the Wii Console does carry a one-year warranty.
We are happy to inspect and, if necessary, fix the system at no charge within the warranty period. To start the repair process, click here.
function rvl_ts_sys_power_no_light_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_power_no_light",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_power_no_light_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) } function rvl_ts_sys_power_no_light_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_power_no_light=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_power_no_light_techDif(){ //it broke document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_power_no_light_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_power_no_light_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) }
Dec 25, 2011 | Nintendo Wii Console
My Satellite A135-S4527 will not power up. I press the power botton it lights up in color blue (as normal) and the power on LED indicater lights up. This will stay on for appox 10 sec and goes off. No HDD...
check your power fan of your processor underneath on the laptop, possible cause is overheat, bring it to the shop for whole diagnosed.. if you continously used on that situation it might cause some problems to other parts due to overheating..
Aug 27, 2011 | Toshiba Satellite A135-S4527 Notebook
Led power & hard disk led on for few sec,no display,switch off
hi,
can you please be more specific?
i had a c640 with the same issue..
the cause was a power short to the cpu..
wich meant the cpu didn't get power..
the metal base under the board gave the board to much presure
the metal base was bent
as soon as i took of the fan he started normal..
so what uou can do:
take the fan off , and try to power up..
just a few seconds..
also the cdrom or flop can cause a short, maybe you can try that first..take them out and power up
May 21, 2010 | Dell Latitude C610/C600 Pentium III...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Mar 23, 2008 | Computers & Internet
OUT OF PAPER
1.Try downloading firmware
2.Check for driver
3.Check for LED indications on printer front panel.
4. Try removing dust between fork sensors situated below card feeder.
5. Try removing dust below ribbon sensor plate (blue led ) .
6.Do self adjustment
Hope this helps
Mar 15, 2008 | Evolis Dualys Thermal Card Printer
HP StorageWorks MSA1510i/MSA20 (AD594A) Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
