Question about Refrigerators
My Daewoo refrigirator's freezer is cooling but not the lower com
I purchased a used Daewoo refrigirator's couple of days back. The seller showed me it that it is working fine when I went to see it but when I went to take the delivery he had switched it off. I brought it home left it unplugged for 1-2 days. When I switched it On it started to cool but the cooling was not that much. In next 1-2 days I observed that the freezer is cooling but not the lower compartment. If I switch it off for 8-10 hours it starts to cool (not very cool though) but after a day or two the lower compartment becomes hot again. The freezer also is not that cold to completely freeze meat and other stuff. Please help
  • vnsons1 May 31, 2010
    Sorry forgot to ask...can I change the setting of the defrost if yes how..Need your urgent help
    President:
  • 2,468 Answers
Sounds like you need to replace the ptc overload on the compressor as this component supplies start and run power to the compressor and its getting weak and short cycling the compressor,they just unplug and plug into the side of the compressor and when you remove it shake it by hand and if you hear it rattle thats a good sign its bad
Posted on May 31, 2010
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
I get ice build up in lower shelf of freezer and water leaking into top shelf of refrigirator What should I o?
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Whirlpool Refrigerators
I AM USING A DAEWOO REFRIGERATOR. THE UPPER CHAMBER OR THE FREEZER IS VERY COLD BUT THE LOWER CHAMBER IS NOT COOLING . WHY IS THAT SO?
Hello Nickel129,
I understand that you are having a problem with the refrigerator. The freezer is cooling just fine however, the fridge is not cooling enough or at all.
1. Check to see if you here the fan in the back of your freezer compartment turning.
a. if you do not here the fan then you need to replace it.
1. Unplug unit (fridge)
2. Remove the screws holding the bottom (if any) and the back cover.
3. Locate the fan and remove the wires
4. unbolt the fan and remove the fan blade (some new motors do not come with the blade)
5. Purchase a new motor at a local hardware/appliance store
2. If the motor is running you need to check the air tunnels (pasages in the frezzer)
a. Remove the covers in the freezer as above. There will be one, two or three holes that go thru the bottom and into the fridge. If these holes are full of ice defrost (w/water, hair dryer, etc.) so that air can pass thru the holes.
The above should help you to fix your refrigerator.
Thank you for choosing Fixya.com for your questions
Justin
Mar 19, 2011 | Refrigerators
The freezer maintains the temperature, but the refrigirator shows 47 degrees irrespective of the setting.
heatman101
Nov 29, 2010 | Amana Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 02, 2010 | GE GSH25JFT
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
