Question about Canon MX700 Office All-In-One InkJet Printer
Epson MX700 fault - piece came loose inside I need advice please on replacing a piece inside my Epson MX700 printer that has come adrift, and how to do it. I recently experienced a problem in the paper feed path. Sheets would pass under the print heads (they were inked), but would then become jammed. The jam was caused by a piece of foam stuck inside the mechanism - I removed it with tweezers. Most of it (a 7 inch piece - see images here: http://img441.imageshack.us/img441/9641/epsonfoam.jpg ) came out in one piece, but a portion (I estimate a further 2 inches) was destroyed in the process. The printer appears to be working normally again. However, I don't know what the foam was doing, or whether I will eventually have reason to miss it. It has a regular pattern of ink stains on it (see upper picture) - could it be needed for head cleaning perhaps? I have several questions: - Does anyone know what the foam did, and where in the machine did it come from? - Should I leave things as they are, or replace the 7 inch section I still have, or procure a replacement part?
  • 241 Answers
The piece that you showed in picture looks like it could be your ink absorber pad. This part is usually found at the side of the printer where the cartridges rest after each print job. You can run the printer without it, but if you can find exactly where it belongs it does catch the excess if that drips from the cartridges.
Posted on May 31, 2010
"A printer error has occurred - see your documentation" I don't have my documentation, can you supply an answer, please?
Following the advice to open the glass cover and look for the lock, I found that a stray piece of paper was inside the printer. Removing it has fixed it. Thanks for the pointer.
Oct 21, 2010 | Epson Stylus RX560 All-In-One InkJet Photo...
There is a line down the right hand side of anything I scan on my MX700. Anyone know who to fix this?
roller in side is scored or worn and picking up line in rollers does it happen when you just print?
try to clean inside maybe a piece of debris is in there
Feb 18, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Ive got a pixma mx700 printer and im getting the 5c00 error how do i get rid of this
Error code 5C00 refers to possible paper jam or product needs reset or service.
It is possible that a previous paper jam has left a piece of paper inside the machine. If you cannot see any paper jammed at either input area, open the rear cover and look in there. Otherwise, you can try to reset the product:
Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on
If all of these suggestions fail, your MX700 may require repair service.
Dec 28, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Cannon MX700 Output is blurred
You will have to replace the print heads on this printer. They most probably got damaged when you pulled out the paper jam.
Aug 12, 2009 | Office Equipment & Supplies
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
Fax not sending or receiving
The fax function is controlled by a fax card on the inside of the printer. Most likely, that card has failed. You will need to contact Canon to get a replacement card and instructions on replacing it.
Thanks and please take a moment to give this a good rating of fixya.
Dec 24, 2008 | Canon PIXMA MX700 All-In-One InkJet...
MX700
Solution:
1. Unplug the printer.
2. Remove the faulty Cartridge
3. Plug in the printer and press and hold power button
4. Keep it held down. Press Resume twice, and this should reset the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
97 people viewed this question
old marine
old marine
