Open the message you have received
press and hold on the message - and select "copy"
Open a new message and select the new recipients.
In the message box, press and hold then
In the message box, press and hold then select "paste" then send the message
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye: 1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET 2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK 3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW 4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL 5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100% 6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows: 1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK 2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL 3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100% 4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
Hold the announcement key down. If the old message is there it will read it out loud to you. If you wish to change it, just hold the announcement key and speak over the old message. Make sure you keep holding the announcement key as you record your new message. When you have finished recording, release the key. If you wish to hear your message push the announcement key again. Do not hold it down this time. If you are not satisfied with the new message, repeat the method by holding down the announcement key again and recording your message. Your old message will disappear once you have recorded your new one.
To remove a sent text messaging in SamsunggalaxyS3: Open the Messaging app. 2. Tap and hold the message thread until a menu appears. 3. Select Delete thread. To delete individual text messages from Samsung Galaxy Tab: 1. Open the Messaging app.2. Select the message thread that contains the item you wish to delete. 3. Tap and hold the message until a menu appears. 4. Select Delete message.
Remember messages vary in length and you may just have longer messages taking more room than before. Also have you checked and deleted other message boxes like 'sent', 'out box',& 'drafts'? Hope that helps?
Vehicles Without Message Center
To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center
To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
First, delete all messagegs in the out and in box. Clear the cashe. (Open browser, press menu key select clear cashe). Do a power cycle. Then you'll wanna look at your settings. You could be saving your text messages to your sim, which doesn't hold a lot. Also ,if you have pictures that can cause a memory issue. If you use the web, that can cause memory issue. So, please make sure once a day your shut down your razr for about 10-20 seconds. This will give it a nice reboot and work like a dream. What you can do is change the setting of storing
all incoming messages. Its normally set on saving all messages to the
SIM which doesn't hold that much memory. If you change it to store your
messages to your phone, you can hold approx. 200+, after you reach the
200 msg mark, it will start sending MMS messages
If you are looking for a message on hold port, you will not find one. Technically speaking, this is not a phone "system." There are 2 options for using messages on hold with your phones: 1) Using a message on hold player with a built-in adapter 2) Using a message on hold player and a separate adapter
The best option can be a little tricky to determine. We work with hundreds of small businesses that have 2,3,4 line phones and can help you figure this out and deliver the best solution. Please call me.
800-832-4653 ext.240 (Drew, Sales Mgr, Commercials On Hold)
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
