Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Yes, it is in VCR Mode...
When I plug in my camera using an iLink (4 pin to USB), my PC does not recognize the device. Do I need a driver?
Comment by tooferone, posted on Apr 08, 2008 Yes, it is in VCR mode. FYI I have Windows XP Professional. I think maybe this version of Windows does not recognize the camera, or maybe because I'm using a 4 pin to USB firewire instead of a 4pin to 4pin. Any thoughts?
I have the same problem using a 4 pin to 4 pin cable
Posted on Apr 19, 2008
  • 78 Answers
You need a 6 pin to 4 pin firewire cable, friend :) It should work with one of those.
Posted on Apr 08, 2008
The LCD screen has suddenly stopped working. The Handycam is a DCR-42,purchased in September 2005 and sparingly used. I have given it to Sony Service Center at Arabinda Sarani, Kolkata, India. How do I...
See this, it answers to most of your queries:
http://www.fixya.com/support/t5921707-convert_mini_dv
The CD that came with the camcorder is not compatible with Windows 7. You have to go to Sony's site and get an update. See if the following link is useful:
http://www.sony-asia.com/support/download/415262
I think USB streaming is not supported in Windows 7, so probably iLink is the only option available to you, which anyway is better than USB in terms of less frame drops and capture of DVD quality. The camera has 4 pin ilink port. Check whether you have 6-pin port or 4-pin port or both type of ports on your computers. Laptops generally have one 4-pin port. Desktops can have more than one iLink ports and can have both 6-pin and 4-pin. 4-pin port would look exactly like the one you have on your camcorder. You can find a photo of 6-pin ports at
http://en.wikipedia.org/wiki/File:IEEE_1394_Firewire_PCI_Expansion_Card_Digon3.jpg
If your both the computers have at least one port with same number of pins, then you can use one cable for transferring to both.
You will need an ilink cable with 4-pin male to connect to camcorder and either 6-pin male (http://cgi.ebay.in/4-Pin-6-Pin-DV-iLink-Cable-/400180203017?pt=LH_DefaultDomain_203&hash=item5d2c994e09)or 4-pin male (http://cgi.ebay.in/4-Pin-4-Pin-Firewire-IEEE1394-DV-iLink-Cable-/400180205113?pt=LH_DefaultDomain_203&hash=item5d2c995639) to connect to the computer side.
Dec 09, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Cyber-shot 1.3 Mega Pixel
Try out all these options one by one t fix your problem:
1)just try to unplug the device and have it connected into another PC (with USB port) and let it be recognized by that PC... when it is recognized, plug it again to the original PC it was previously plugged. i know it doesn't make sense but i believe there are some electrical factors that may cause this malfunction.
Another way is... just leave it UNPLUG for half a day or a whole day, and plug it again... probably it will recognize the device itself.
2)install the mainboard drivers of USB so that it can run USB 2.0 devices..........that's it..........
3)Backup your important data in the system partiotion. Then format it and reinstall windows XP fresh copy
4)Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying icon_smile.png.
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 06, 2008 | Cameras
No driver for sony handycam trv30 using windows 7; can't find a driver that will work with firewire 1394
usb streaming is not supported by your new windows OS,reason usb driver is not available. for ilink or ieee1394 connection it should be a plug-and-play connection. no setting in the camera enables or disables ilink output and an ilink driver for the camera is not needed to support this connection (not unless you need to update or reinstall your ieee1394 device driver to get it to work). check this solution link: http://www.kb.sony.com/selfservice/microsites/search.docmd=displayKC&docType=kc&externalId=C86798&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=157560925&stateId=1200%20157576924
hope you can get to establish connection.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
DO I REALLY NEED A FIREWIRE CARD?
If your camera is Firewire, iLink,or IEEE 1394, then you need Firewire support or a Firewire card.
If your camera has a USB symbol, or says USB anywhere in the manual, you can use USB for the functions it allows.
There is no USB to Firewire or Firewire to USB without the use of an advanced device.
May 12, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
