Computers & Internet Logo
Anonymous Posted on May 31, 2010
Toshiba Qosmio G55-804 keyboard not working. - Computers & Internet
Achalesh Prem P
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 135 Answers
  • Posted on May 31, 2010
Achalesh Prem P
Expert
Level 2:
Mentor:
Answers
135
Questions
0
Helped
45447
Points
395
Testimonial: "Great Respond current."
2answers
How to replace the keyboard of Toshiba Qosmio
How to Remove Replace and Install Your Toshiba Qosmio X505 Laptop Keyboard
1. View the back of your Toshiba X505 Keyboard. If the laptop keyboard has screw holes, then you now you need to remove screws from the bottom base of your plastic bezel. If the keyboard does not have any screw holes, then screws are usually not required to be removed from the bottom of the laptop.
2. Now that you have determined if screws are required to be removed from your Toshiba X505 laptop keyboard, we will now pry the keyboard out using a thin object. The first step is to view the top of the keyboard area, also known as the keyboard plastic bezel. If your keyboard has a plastic bezel above your keyboard, you will need to pry it out. If you don't have a plastic bezel above your keyboard, then you can take a think object. Place the thin object between your Toshiba X505 laptop keyboard and the plastic bezel, and pry out the keyboard.
3. Now that your Toshiba X505 keyboard has been removed your will need to disconnect the Toshiba X505 keyboard cable ribbon from the motherboard. There is usually pins connected to the Toshiba X505 motherboard that need to be pushed up/down. Once the keyboard connector cable has been removed from the Toshiba X505 laptop keyboard, remove the keyboard.
4. We will now install your new Toshiba X505 laptop keyboard.
5. Reconnect the Toshiba X505 keyboard to the motherboard. Insert the Toshiba X505 Keyboard back into the motherboard. Secure the pins and push the pins in. Once your keyboard is secured, you can now aligned the keyboard with the grooves. Push the keyboard down and in place. If there is a Toshiba X505 plastic keyboard bezel, place it back in place. Secure all your Toshiba X505 laptop screws back in place.
6. That's all, you just installed your replacement notebook keyboard!
Toshiba Qosmio x875 keyboard suddenly stops working
pls remove the key board ribbon cable and re seat again
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
1helpful
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Keyboard Not working correctly
Replace your keyboard with new one, having actul model of the notebook.
Regards;
Hassan
1helpful
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Toshiba Qosmio G15-AV501 red lines in lcd hi i have a problem toshiba qosmio power on password.its model number(pqf10a-015008).how to solved the password removed.
pop the keyboard and look on the board next to the clock battery. You should see three jumper points, WITH THE POWER OUT AND ALL BATTERIES DISCONNECTED, short terminals 1 and 2 with the end of a flat bladed screwdriver. Replace all power sources and reconnect the power.
How do i enable the buttons on the top of my keyboard. (toshiba qosmio - laptop) as my friend accedently disabled it and he doesn't know how to enable it?
http://www.ebookspdf.com/computers/2149/toshiba-qosmio-g30-users-manual/
Folow the link  and you will find user manual for your laptop and mozt important the solution for your problem
Have fun dude
Regards
Grand Canyon Tech
Grand Canyon Tech
